FutureBoy
- Reginald
- Oct 1, 2020
- Kirkland WA USA
- Toyota Sienna
- Occupation
- Financial Advisor
- Thread starter
- #1
How Silverado EV Stacks Up Vs Cybertruck, Rivian, Hummer, And Lightning
How do these five electric trucks compare on paper?
Jan 06, 2022 at 4:58pm ET
By: Jeff Perez
Electric trucks: so hot right now. With some of them reaching dealerships in 2021, others arriving early this year, and at least two more on the way in the years to come, soon the market will be saturated with all varieties of battery-powered pickup.
With so many options to choose from, you're probably wondering which EV truck is worth your money. Until we're able to get all of them together for a proper comparison test, it's impossible to definitively tell you which one is best. But, we can at least peruse the specs sheet and look over the stats so that you have an idea as to what each one offers.
The Chevrolet Silverado EV is the latest to join the fray, making its virtual debut as part of the 2021 CES show in Las Vegas this past week. But the list of contenders also includes the Ford F-150 Lightning, the GMC Hummer EV, the yet-to-reach-production Tesla Cybertruck, and the Rivian R1T. So let’s see how they stack up.
Price
How much are these battery-powered trucks going to cost? Some of them, like the Rivian and Hummer, aren't attainable to the everyman – but they do come loaded with features, unlike some of the more affordable trucks. The R1T starts at $67,500 for the base Explore trim, while the Adventure model brings the asking price up to $73,000. The GMC Hummer EV Edition 1 is even pricier, asking $108,700 out of the box. But the base model will start at $79,995 when it goes on sale in spring of 2024.
On the more attainable side, the Tesla Cybertruck has a rumored starting price of $39,900 for the base single-motor, rear-wheel-drive model (if that's still happening). The Ford Lightning Pro starts at $39,974 (before $1,695 in taxes and fees), with the top-end Platinum trim asking $90,874. The Silverado EV, when it goes on sale, will cost $39,900 (before fees) for the base Work Truck trim and $1056,000 for the top-end RST model.
As far as availability is concerned, the GMC Hummer EV and the Rivian R1T are the only two trucks that made it to customers in 2021. Although, technically speaking, Hummer only sold one (1) example in 2021. Nonetheless, the Lightning should hit the road early this year – but we will have to wait for the other two.
Tesla says the first examples of the Cybertruck should roll off the production line sometime this year, following months of delays. And Chevrolet says the First Edition variants of the Silverado EV will make their way to customers in 2023, while the rest of the model line won’t debut until at least 2024.
Capacity & Range
Naturally, you want to know what powers each of these machines. In the case of the Silverado EV and GMC Hummer, those trucks use GM's new Ultium battery pack. While Chevy hasn't released specifics on the Silverado EV's overall capacity, we can safely assume that it holds the same 200.0 kilowatt-hours as the Hummer in the top-spec RST trim. The base Work Truck, Chevy says, will have a smaller battery pack and capacity.
The base Ford Lightning offers two battery capacities. The company confirms a usable capacity of 98.0-kWh in the base model and 131.0-kWh in the upper trim, with estimates putting the gross capacity at 110.0-kWh for the base trim, and 145.0-kWh for the extended-range model. The Rivian R1T, meanwhile, packs a gross capacity of 135.0-kWh, while the Cybertruck is rumored to offer up to 250.0-kWh – which would make it the largest of the group.
If the Cybertruck does make it to market with that massive battery pack equipped, it would have the best range of the bunch; Tesla says it could drive up to 500 miles (805 kilometers) on a single charge with the quad-motor setup equipped. The Silverado EV would be the next-best with 400 miles (644 km) of range. But when it comes to electric trucks currently on sale, the GMC Hummer EV is the range king with 329 miles (530 km) on a single charge, followed by the Rivian R1T with 314 miles (505 km), and the Ford Lightning with up to 300 miles (483 km) of range.
Charging
The new Silverado EV (in RST form) and the Hummer EV offer the fastest charging rates of any other electric truck – and most other EVs for that matter – up to 350 kilowatts. That means these two pickups will be able to recoup 100 miles of range in just 10 minutes at a compatible DC fast charging station.
Next-best is the Rivian, which achieves rates up to 210 kilowatts and can recoup 140 miles in 20 minutes. The Ford Lightning is behind the eight ball comparatively, charging at a maximum rate of 150 kilowatts, and juicing from 15 to 80 percent charge in 41 minutes.
Tesla says that the quad-motor Cybertruck (formerly the tri-motor model) will be able to charge at a rate of up to 250 kilowatts, which would put it above the Ford and Rivian, but still below the Silverado and Hummer. Hopefully Tesla releases more specifics ahead of the truck's debut, which is scheduled for this year.
Power
Range and battery capacity are definitely huge factors when considering an electric truck, but for a lot of people, power still plays a role. The good news is that all of these trucks pack plenty of it.
Tesla claimed 800 horsepower (597 kilowatts) and a 0-60 time of 2.9 seconds in the Cybertruck tri-motor model. But with news of the new quad-motor model, those figures could be even better. As far as production trucks go, the GMC Hummer EV is the fastest and most powerful, with up to 1,000 hp (736 kW) on tap and the ability to hit 60 miles per hour in just 3.0 seconds via its "Watts To Freedom" – or WTF – launch control system.
Just behind the Hummer is the Rivian R1T, with an impressive 835 horsepower (614 kW) and the ability to hit 60 in just 3.5 seconds. The Ford Lightning, meanwhile, offers 426 hp (313 kW) in the base model and up to 563 hp (414 kW), with a 0-60 time of 4.5 seconds. And when the Silverado EV officially goes on sale in a few years, Chevy says it will have 664 hp (488 kW) and a 0-60 time of 4.5 seconds using the Wide Open Watts (WOW) launch control model – but the base model will be far less powerful.
Towing & Payload
These are still trucks, after all, so they need to do truck things. Towing and payload capacity are still two of the biggest factors buyers consider when looking for a new pickup.
Believe it or not, the Rivian R1T is the top towing truck of the group of production models, able to tug 11,000 pounds (4,990 kilograms) with the quad-motor option equipped. The payload figure is impressive too, second-best in the segment at a hearty 1,760 pounds (798 kg).
The Ford F-150 Lightning and Chevrolet Silverado EV can both pull up to 10,000 pounds (4,536 kg) in the right spec – and Chevy even promises a later HD version that can move 20,000 pounds (9,072 kg). The Lightning wins the payload award, though, with the ability to haul up to 2,000 pounds (907 kg) with the smaller battery pack, while the Silverado and Hummer fall just short of that figure with a max payload capacity of 1,300 pounds (590 kg). And the Hummer only tows 7,500 pounds (3,402 kg) by comparison.
Tesla, though, says that the Cybertruck will beat all of them when it goes on sale. The quad-motor model will reportedly be able to tow at least 14,000 pounds (6,350 kg) and haul up to 3,500 pounds (1,588 kg).
Update (1/07/2021): Pricing for the base GMC Hummer EV has been added, and the torque and capacity figures have been updated to reflect the Edition 1 model.
By: Jeff Perez
Price
Base Price | |
Chevrolet Silverado EV | $39,900 |
Ford F-150 Lightning | $39,974 |
GMC Hummer EV | $79,995 / $108,700 (Edition 1) |
Rivian R1T | $67,500 |
Tesla Cybertruck | $39,900 |
Capacity & Range
Max Capacity | Max Range | |
Chevrolet Silverado EV | 200.0-kWh (est.) | 400 Miles (est.) |
Ford F-150 Lightning | 110.0 / 145.0-kWh | 230 / 300 Miles |
GMC Hummer EV | 200.0-kWh | 329 Miles |
Rivian R1T | 135.0-kWh | 314 Miles |
Tesla Cybertruck | 250.0-kWh (est.) | 500 Miles (est.) |
Charging
Max Charging Rate | |
Chevrolet Silverado EV | 350 Kilowatts |
Ford F-150 Lightning | 150 Kilowatts |
GMC Hummer EV | 350 Kilowatts |
Rivian R1T | 210 Kilowatts |
Tesla Cybertruck | 250 Kilowatts (est.) |
Power
Power | 0-60 | |
Chevrolet Silverado EV | 664 HP / NA | 4.5 Seconds (est.) |
Ford F-150 Lightning | 426 HP, 563 HP / 775 LB-FT | 4.5 Seconds |
GMC Hummer EV (Edition 1) | 1,000 HP / 1,200 LB-FT | 3.0 Seconds |
Rivian R1T | 835 HP / 908 LB-FT | 3.5 Seconds |
Tesla Cybertruck | 800 HP / 1,000 LB-FT (est.) | 2.9 Seconds (est.) |
Towing & Payload
Max Towing | Max Payload | |
Chevrolet Silverado EV | 10,000 Pounds (est.) | 1,300 Pounds (est.) |
Ford F-150 Lightning | 10,000 Pounds | 2,000 Pounds |
GMC Hummer EV (Edition 1) | 7,500 Pounds | 1,300 Pounds |
Rivian R1T | 11,000 Pounds | 1,760 Pounds |
Tesla Cybertruck | 14,000 Pounds (est.) | 3,500 Pounds (est.) |
