Leifmb
- Leif
- May 12, 2024
- California
- 2025 Cyberbeast
Looks much better and I bet even better without the caps!
Road noise way better than the AS I had .I have the same question - road noise. I love the look but hoping the road noise is a bit better than than the stock AT tire, which honestly is fine.
Do you have photos of one of your fleet trucks? Just like seeing pics.I basically live between several locations in the mountains and used to drive in every Utah storm (700k miles on my fleet) at all hours of the day (think no plows, zero visibility) and there’s no chance that I would be running AT tires in my fleet especially if you’re just “occasionally” going up into the mountains. Those are fine for off roading but they aren’t usually siped for all around variable temperature wet traction (with exceptions of course). If you want the best all around conditions traction you want to start with a good AS tire which for my fleet were Yokohama YK580s and get them siped at Les Schwab (or whatever shop that will sipe them). This gives you optimal noise, tire wear, and range.
The trade offs are not worth it IME vs just having better driving skills/judgment and swapping to ATs for actual off roading (or not even bothering).
The CT also has glitchy rear steer that can cause you to slide your rear end very easily in the normal drive modes. It is independent of your tires and more a function of the way the vehicle fails to maintain traction when the suspension is under some variable load like in a wet corner with “full lock”, over a grate, with a bit of steepness, etc. It’s probably something Tesla needs to tune into the traction control system as I have seen it happen multiple times in dry and wet conditions. I used to see this in my Fiat 500e if I hit a variable grade while steering and I would spin my front tires on dry ground due to the stiff suspension.
Ironically they don't look as aggressive on the cybertruck as they do on other trucks I've seen them on. LoLhow you like my setup ?
These are my plan with probably the Martian Wheels 18" Cyber Rover beadlock wheels, they seem to be the most reasonably priced right now. We've also seen a cybertruck all over offroad with them.
Did you go with the 35"x12.5" or the 285x60/70/75 tire size?
My favorite tire! Those look great! Let us know how they are working out.how you like my setup ?
I went with the stock size … 285/65/20Ironically they don't look as aggressive on the cybertruck as they do on other trucks I've seen them on. LoL
was it cheaper than the 3.5k all terrain factory upgrade?how you like my setup ?
The BFG KO series is their all terrain series, best for on/off road general all weather travel with an off road leaning bias. The tread pattern is designed more for road grip.guys, Ive owned KO2s and KM3s, felt the KM3s are the successor, but now KO3s are available
please explain the KO3 vs KM3 difference
You need a set of steel wheel from t sport line for you off road tires. I have as but I about buy a set it at tireshow you like my setup ?
