Mileage
RVAC
Tesla does calculate their EPA range differently then other manufacturers (which the EPA allows) . This article explains it pretty well. But its the reason why most other manufacturers meet or exceed their EPA range and Tesla often falls short.
https://electrek.co/2023/07/27/tesla-vastly-overstates-its-vehicles-range-report-states/#:~:text=Tesla conducts additional range tests,more conservative estimates, Pannone said.
I would like to see the EPA force everyone use the same method and also make the manufacturers post a separate city and highway (70 MPH) range estiamate instead of this mixed fantacy.
To be fair that Electrek article is a collection of hit pieces. Displaying range based on the EPA rated consumption can in no way shape or form be construed as rigging range estimates. Tesla is also not the only manufacturer using the 5-cycle test and the Lightning, which is rated on the 2-cycle test, sees about the same range loss when doing a 70mph highway run. That said I do agree the EPA should have everyone test on the same cycle.
Arctic_White
Ray
Edmonton, AB
Model S Plaid; CT on order
but fundamentally, the mistake you appear to be making is this:
the “Tri Motor” described in 2019 is not necessarily coextensive with every model variant that ever comes out with three motors.
Put differently, on Nov 30 they aren’t releasing that “Tri Motor” at all.
They’re selecting something that sort of looks like the “Dual,” plus a new variant never before discussed, which is essentially the “Dual - Performance” (which merely happens to use three motors to achieve the ‘performance’)
I see.
Well damn. I guess I will be bathing in my tears if there is no 500+ mile version announced in a few weeks. :ROFLMAO:
I see.
again, good news is, what’s announced in the next few weeks may only be relevant to the first ~year’s worth of orders, which may be only 30K-70K people
by the time most people get to order, what’s being offered in a few weeks is old news, and possibly irrelevant to the then-available models
early adopters get early model offerings ??‍♂
Arctic_White
Ray
Edmonton, AB
Well, in this case, I will likely just wait until the 500+ mile range is offered (well, technically 400+ mile range is my requirement).
Basically, what you're saying is that you doubt that initial production will have the 500+ variant offered. I think otherwise but I can see your point and appreciate where you're coming from.
Let us wait and find out! :)
Crimson_Fate
Scott
Same here , I'll pass until a 400+ model comes . I can definitly see the 500+ mile version not happening until they add silicone to the 4680 but a 400+ version should be possible.
Arctic_White
Ray
Edmonton, AB
that’s not what I’m saying
remember the whole kerfuffle last week? ?
ignore as you see fit!
Oh yeah.
I couldn't quite convince you about the dealer network, but check this out: Ford Dealers Do Not Trust The Blue Oval: Report (fordauthority.com)
Dealers are pushing ICE vehicles over EVs because their profits and sales commissions depend on them.
Do you still prefer the dealership model? Do you still believe that OEMs are not actively trying to bypass the dealership model and sell to customers directly? Or all of that is just a game that the OEMs are playing?
:p
PilotPete
Pete
Porsche, BMW, M3LR on order
Chief Pilot
performance model weight will be nominally heavier - but discharge rate and resulting power, ‘tuning,’ etc, higher - eg through different ‘performance’ inverters.
now from THERE if they wanted to be EVEN faster than the performance, tuning optimized etc, THEN they’d need to drop weight
I want performance. I'm not buying a "truck", I'm buying the tech and performance.
Assuming a weight of 6500#, the online calculator says you need 1034 HP (in an ICE) to get to 2.99 sec 0-60. Another says an electric direct drive with performance tires needs 755hp, but with normal tires, you can't get below 3.08 sec
That said, the CT is getting competition. The new price on the MS Plaid is tempting (And blindingly fast) and the rumors of the M3+Ludacris make me want to take a moment and think. Since I'm not in a position to brag about where I am in the reservation que, I have time to make a decision.
If I could pick and choose, I'd take the MSPlaid, add the 4WS of the CT, the display of the CT, and some of the yet to be mentioned tech of the CT, and I'm good. I'll sacrifice down to sub 3 sec 0-60 to get the tech, but not much more. I've waited for a loooong time to buy a 3.X second rocket. I've only recently abandoned a turbocharged flat 6 for a multi-motor electric setup. But now the I have, there is no going back.
I have every *expectation* the base dual motor will match the Lightning Lariat ER’s 3.9 sec 0-60
from there, one has to imagine, to justify the segmentation of trim, what the ‘performance’ / cyber-“beast” version will have to do
sub-3 would have to be it
your physics/rubber questions noted, but more begs the question of what rubber they’d have to offer on that model (if one wants to achieve the speed)
put differently, will it ever make sense to pay for a performance trim but put ATs on it?
pay for all that Performance vs base, the. hobble it?
PilotPete
Pete
Chief Pilot
But you are only hobbling it off the line. Look at the 30-70mph acceleration. I don't think even ATs would be that hobbled in performance. Or towing acceleration, or just hauling 1X,000# in a trailer. If you are entering a highway at ~40 and you need to step on it to merge, are your ATs a big constraint? They might even be a benefit in the heavy rain or some other contaminated scenarios.
I don't think I'll ever have off-road tires on mine. Where I live and where I drive, I use only summer performance tires on my current vehicles. I see the same for the CT. Maybe a different tread pattern...
Like I said, those test conditions are prescribed by the EPA, not Tesla, and every manufacturer has the option to use whatever methods can eek them a small advatage. If you drive under the test conditions, you should get the EPA results. Porsche has tried to get their Taycan EPA numbers higher by repeating the testing in various ways, but failed. I believe they even asked the EPA for an exception, but were denied.
There is a false narrative that Tesla is somehow less efficient than the rest, relative to their EPA numbers, and this is apparently supported by various third parties out to discredit Tesla any way they can, but there are also unbiased testing that shows Tesla in line with most other manufacturers in terms of real-world testing vs. EPA numbers.
You could write a book on this, including the way most third-party tests leave more unused range in the bottom of the Tesla battery pack (because they decided the display reading "0 miles left" means the car is done driving while EPA testing drives until the car can no longer maintain the prescribe drive cycle).
The attacks on Tesla range accuracy have been numerous enough and loud enough that I'm sure many people sincerely believe it is a fact. This is not the first time that large swaths of observers have been fooled by media bias.
Mike,
I think when people use the term "ideal conditions" they refer to the conditions that most closely match the test conditions. Not necessarily "downhill, with the wind, perfect temp" conditions. We have the same thing with aircraft certification numbers. What's the stopping distance? "Ideal conditions" are new tires, no wind, perfect speed control, not the softest of landings, new brakes, clean (no laid down rubber) runway, etc. Can you find those in the real world? Sure. Every landing? Nope. We refer to them as "Ideal conditions" even though there are conditions that are even better for stopping. It's just a term to refer to the conditions under which the tests were conducted,
Keep in mind that the controlled testing that showed the original 2018 Model 3 with an EPA range of 310 miles could actually go well over 600 miles under ideal conditions did not use tailwinds or negative elevation gains to game the "ideal conditions", they merely travelled at a steady speed that was near the peak efficiency speed without stopping or going into regen braking. They were also on smooth roads in weather not requiring the use of cabin heaat or cooling, the radio was not on, the fog lights were not on (who runs fog lights during clear weather anyway).
Under conditions that most closely match test conditions, a Tesla will return the EPA range. It is proven by the EPA testing. The conditions prescribed by the EPA drive cycles are not ideal because they include numerous accelerations/decellerations at specific rates, stopping, starting and speeds that far exceeds the speed of maximum efficiency.
oh I agree, generally
but for the same reasons, you’re really talking off the line being the big difference maker
meanwhile, the performance range will already be a bit knocked down compared to dual. Then put on the ATs and, at hey speeds, knock another 25-30% off range (also true for Duals btw), then suddenly it could be a big price premium for not a lot of performance difference
just a musing
PilotPete
Pete
Chief Pilot
just a musing
Everyone has a different usage case. For ME, my normal round trip is less than 150 miles. My "long haul" drive is less than 300 miles. I fly everywhere else. Heck, I had a meeting 127 miles away and I flew to that one! So while I'd like 500 miles for bragging rights, I'm not inclined to pay extra for it in either cash or weight. Again, that's just me. I know there are "real truck guys" out there with other needs.
Sirfun
Joe
Oxnard, California
Retired Sheet Metal Worker
I need to pull my tractor. Hills of Arkansas. Lack of charging station where I live.
Most people with EVs don't need a charging station where they live. They charge at home and that's a huge bonus. Any morning when you get in your vehicle it's charged and ready to go. What you need charging stations for is a trip away from home. And Arkansas has quite a few.
