Cybergirl
Illinois and Arizona
On my off road adventure trips, I generally carry a lot of camping equipment in the vault leaving little if any room in the vault for a spare tire, and the last thing I want is to be stranded miles from civilization with an unpatchable tire. My solution is to install this CybertruckCo roof rack on my CT and take along my full size TSportline A/T spare tire strapped to the top.
Tesla Cybertruck My Spare Tire Solution - Mounted on Roof Rack Roof Rack 1 (1)
Tesla Cybertruck My Spare Tire Solution - Mounted on Roof Rack Roof Rack 1 (1) copy
The roof rack from CybertruckCo is made of strong extruded aluminum billets coated black. I attached them to two of the four pairs of CT's mount points. The quality of the materials is very good. Everything is cut to size and fit the truck perfectly. Unfortunately, the kit came with no installation instructions and none are supplied on line. I struggled with the installation as a result. It looks straight forward at first glance but first impressions can be deceiving. The two long billets are different lengths, duh!, and the way the billets are connected together requires careful planning because if you make a mistake locating one thing, it often means disassembly the whole thing to correct it. Each bolt screws into a flat threaded nut that has to be slid into the billet from its end. It's a lot harder than it sounds.
I learned that the best way to assemble the structure is to mount the cross beam over the glass roof first with all the connection pieces and hook plates in place. The same for the other (rear) cross beam. Then attach the short beams to the rear beam with the other end resting on cardboard placed on the roof, like this:
Tesla Cybertruck My Spare Tire Solution - Mounted on Roof Rack Roof Rack 2
Once the short beams are fastened to the front cross beam, the rear cross beam can be inserted into CT's mount points and bolted down.
Getting the tire up on the rack was a challenge for me, as well. The tire weighs 96 lbs. It took two people to lift it up on top. Tesla's wheels weigh 87 lbs each. I bought this tie-down to secure the tire. The total cost came to $1745, but my vault is fully available.
I will only carry the spare when I go off road adventuring. I'm sure that even the rack will reduce my range some. The tire much more.
SentinelOne
See Sig
looks good - I'd go that route but I have to have 2 dirt bikes in the back so cant block the front of the bed, cant do tailgate mount, no place underneath - maybe a vertical stand between the bikes....we'll see, for now have plug kit and compressor..
Cybergirl
Cybergirl
A plug kit and compressor is all you need to fix most puncture flats. You can take along a full spare behind the front seats if you can spare the room.
jonesw67
Warren
AR
FS Cyberbeast
anyone have links to a recommended plug kit or repair kit I can get to keep in my CT ?
I dont want to have to keep a full spare in the vault taking up space
thanks
SentinelOne
See Sig
I just bought a full tire repair kit in a nice plastic case that fits in the smugglers bay without taking too much room. That plus Tsportline tire compressor (reasonable specs). Dont know if either is good / bad but at face value they'll do the job....sure they can get me through one emergency and if I dont like them I'll upgrade. What I dont have is a bottle jack or tire iron, but dont think I'll need for basic puncture repair (and smugglers vault is full)
Its pretty disappointing that Tesla didn't design a spot for the spare tire.
There is a designated spot for the Tesla Spare.
I'm not sure if any Tesla has ever had a spare. I know the Model 3 and Model Y don't.
For most driving, there just isn't a need for a spare like there was 70 years ago.
MyFirstElectricTesla
SoCal
Benz
It's my fault for reading too fast, I though you have 70 yrs experience of driving:
70 yrs + 16 yrs (minimum age to have a driver's license) = 86 years ===> you shouldn't operate any vehicle ...
CT_AZ_4x4
Jay
Scottsdale, AZ
AWD CT
Self employed
thanks
Dude;
This tire repair kit is very good. I have one in all of my vehicles.
https://a.co/d/dV0hdLt
Cheers!
CT_AZ_4x4
Jay
Scottsdale, AZ
AWD CT
Self employed
Thanks for sharing! Informative and helpful!
rudedawg78
Ernie
South Carolina
thanks
This is the plug kit I got. I like it because it comes with pliers to pull out the nail/screw and a knife to trim the plug at the end. Plus a bag to store it all in. However, if you have a leatherman or gerber packed in the truck, you probably don't need anything this fancy.
Amazon.com: AUTOWN Flat Tire Repair Kit with Plugs 31 Pcs for Car, Motorcycle, ATV, Jeep, Truck, Tractor Flat Tire Puncture Repair : Automotive
tmeyer3
Trevor
www.meyerwine.com
Computer Scientist, Vintner
I also plan on going CybertruckCo, they're pumping out some great products! Just putting it off because I'm a penny pincher ?
I'll regret it when I get an eventual flat and won't have a spare on board...
