edsonbarron
- Edson
- Jan 15, 2025
- Kansas
- cybertruck
I dont need this at all but my intrusive thoughts caved and i ordered
It actually connects to the frunk power feed which is a separate 400W source from the roof. So it's independent. (Together, they would be less than 400W though).Question about this bar. Since it’s 48v, if you have the oem bar installed and wire it parallel with the oem bar on the roof feed, it should turn on at the same time as that bar. I’m assuming the sum of the two is less than 400w?
Yes. I understand that’s how t-sportline intends forIt actually connects to the frunk power feed which is a separate 400W source from the roof. So it's independent. (Together, they would be less than 400W though).
Yep, the Tesla bar is under 200W as is this one so should work on the same feed.Yes. I understand that’s how t-sportline intends for
It to be used, but supposing one wanted to use the frunk power feed for something else like keeping a power station charged, one could basically y off the red and black wires above the passenger door and run that wire back down to the frunk/front bumper.
Assuming they are under 400w together and don’t trip the roof “fuse” they should both come on when you switch the light on from the screen no?
I wonder if that would mean “on” when you press ditch or flood or both.Yep, the Tesla bar is under 200W as is this one so should work on the same feed.
(Inital post of this thread incorrectly says it runs off the roof, I thought that was what you were referencing)
You need to keep the total load on these feeds under 380w, most safe around 350w or less. The 400w rating is a rating but in reality they trip at lower wattage and you need a little buffer for spikes.Yes. I understand that’s how t-sportline intends for
Thanks for the reply. Was just thinking it would be nice to control your bumper bar simultaneously with the oem bar. Single screen button press. Any situation where I’m turning on the roof lightbar, I’d want your bumper bar on too. This would also allow me to keep the frunk feed for my power station needs as I have it set up now.You need to keep the total load on these feeds under 380w, most safe around 350w or less. The 400w rating is a rating but in reality they trip at lower wattage and you need a little buffer for spikes.
Better plan would be to get our Auxiliary Power System (APS), you can run much more load with zero issue. https://tsportline.com/collections/...tegrated-power-systems?variant=50374174507297
The APS goes in the frunk. You can run all the lights (rooftop, ditch, bumper) off the APS and have a single control / switch for them.Thanks for the reply. Was just thinking it would be nice to control your bumper bar simultaneously with the oem bar. Single screen button press. Any situation where I’m turning on the roof lightbar, I’d want your bumper bar on too. This would also allow me to keep the frunk feed for my power station needs as I have it set up now.
Where would the battery (APS) go in this scenario?Not sure I follow what you’re proposing.
Fair point about accounting for spikes by undershooting the 400w.
What’s the max draw on this bar?
I see. Makes sense. Especially if all my lights came from you, because they are on/off lightbulbs basically. The problem is that I have an oem beast bar and so it needs the green information cable up there on the roof feed to work. Native control from the Tesla screen without a controller is also nice.The APS goes in the frunk. You can run all the lights (rooftop, ditch, bumper) off the APS and have a single control / switch for them.
if you really wanted to do this, I’d try powering a relay thru a parallel tap on oem power feed and use that relay to feed secondary lights - power those secondary lights off frunk or aps.I see. Makes sense. Especially if all my lights came from you, because they are on/off lightbulbs basically. The problem is that I have an oem beast bar and so it needs the green information cable up there on the roof feed to work. Native control from the Tesla screen without a controller is also nice.
Was just wondering if it would be possible to group it with that oem bar. Thats why I was asking about max draw.
Good idea.if you really wanted to do this, I’d try powering a relay thru a parallel tap on oem power feed and use that relay to feed secondary lights - power those secondary lights off frunk or aps.
the Tesla is going to look for excessive wattage on the roof feed - you won’t be able to sneak more lights off that. But maybe a relay will sneak by.
Thanks for taking the time to answer my questions.if you really wanted to do this, I’d try powering a relay thru a parallel tap on oem power feed and use that relay to feed secondary lights - power those secondary lights off frunk or aps.
