SlegMD
Lexus
Medical
Been looking for a light, hope this works! Plug and play, about my skill set!
Nexus6
Mike
Malibu
x.com
CyberBeast, Model X, Chevy Colorado Bison, Chevy Suburban 2500
G700/800 Pilot
It is the outlet screen, you simply toggle on/off the aux feed. Easy!
Oh I thought it would have more functionality like the OEM Roof Light, like dimming to use as an on road running light or driving light.
Is this tied to the Frunk Power Feed then?
You may be winning me over to this. I don’t think I’m ever going to get my invincible frunk cover. Any plan to have a color change version of this? I feel like I want something on the truck that can be amber/yellow for better visibility in potential precipitation.
I used this wrap to change my OEM Roof Lights to Amber. I run my Ditch Lights on 1% every time I drive to act like “Roof Markers”.LZLRUN Extra-Wide Headlight... https://www.amazon.com/dp/B09Z7LQNP3?ref=ppx_pop_mob_ap_share
Tesla Cybertruck NEW Bumper Insert LED Lightbar - 40" Curved Light Bar / 48v (no converter!) / Retain Tow Hook Functionality - T Sportline IMG_6822
T Sportline
T Sportline
Brian
Los Angeles & Atlanta
tsportline.com
Upgrading Tesla Cybertrucks!
It's powered on/off on the center screen, same as stock.
Making it do lightshows and stuff, that's a Tesla thing. As for light output and performance, it's no comparison -- ours way out performs - here is the testing:
TarheelCT
26 SAWD 59k crew 🇺🇸 📐
Question. Will the lights turn off with the vehicle or do you have to manually remember to shut them off?
65SoYoLO
Keith
Long Island NY
2024 CyberTruck
Retired truck driver
TexasRaider
JR
Denton
Cybertruck + MS
Civil
New product announcement! Building on the popularity of our roof-top LED lightbars and ditch LED pods, welcome our latest addition - check it out, these are in-stock and shipping!
Details matter -- focused on retaining 'tow bar' access/usability, properly matching the bumper contour, using 48v LED chips (no voltage converter), stainless steel hardware -- and of course, light output performance. BTW, if you're curious on light output for our main roof top light bar - watch this video: HERE
Tesla Cybertruck Curved 40" Bumper Insert LED Off Road Light Bar / Lightbar
Specifications:
  • Developed by T Sportline for Cybertruck
  • Plug-and-Play Harness connects directly to Cybertruck roof auxiliary wire tap
  • Lights turn on/off using Cybertruck control screen - no added buttons or switches - Seamless OEM control
  • True 48 volt architecture - no voltage converters
  • Bolt-on design, uses factory OEM Tesla Cybertruck mounting points
  • Retains use of tow hooks!
  • Fits inset on bumper, allowing full bumper functionality and protects light
  • Designed with proper curve to match bumper contour
  • All included hardware and brackets made from 300-series stainless steel (no rust)
  • No objectionable increase in 'wind noise'
  • Retains proper and sufficient airflow to through grille opening
Light Bar Performance
  • Size: 40 inch light bar width
  • Lens Combo Beam Pattern
  • Body: Extruded aluminum with black powdercoating
  • LED: Osram 5W LED Chips
  • Voltage: 48 Volt DC - Cybertruck Spec (no voltage converter required!)
  • Wiring: Sealed Deutsch connectors
  • Nominal Power: Single Row - 200W
  • Lumens:
    • Single Row - Raw 19050LM, Effective 10170LM
  • Color Temperature: 6500k
FYI for those who wanted power numbers: 142.7 watts drawn with our curved light bar:
Can we use this if we have already tapped into the frunk power for your ditch lights converter product?
T Sportline
T Sportline
Brian
tsportline.com
Both products use the same power feed. If a customer understands the power drawn from each system they could split the power feed so that it will power each system.
TexasRaider
JR
Denton
Cybertruck + MS
Civil
I recalled there being two connections (I installed the included converter in 2024, so it’s been awhile). But I wasn’t sure if your new product would be compatible to used in concert with another. (Aka the converted is capable of supporting/operating both simultaneously.)
