Official Fix: Tonneau Leak Foam Seal
jsteelo21
Jay
NYC
Depends on your service center, I took my truck to a service center 3x and zero change, took it to a different one and it was fixed first time.
I'm in NY, had the same experience. Took it to one service center last year they added a slat but nothing changed. Took it to another one last week as part of a PCS issue and they did the below:
Correction Inspect For Exposed Water Management Channel;
Install Additional Tonneau Slat
CHAIN BUSHING HULL PART - TONNEAU SERVICE KIT(200698700-A) 2.00 SLAT
BOLT - ROLLER TONNEAU SERVICE KIT(2006980-00-A) 2.00 BUSHING SLAT - SEAL ASSEMBLY - TONNEAU SERVICE KIT(200697800-A)
Correction Test To Confirm Water Ingress No Longer Present
Correction Applique - Upper - Tonneau (Long Range) - Remove and Install Parts Replaced or Added Part Quantity SEALING FOAM(1098720-00-B) 2.00
SanJuanCT
Steve
Telluride, CO.
2025 AWD Cybertruck, 2022 MYLR
Business Owner
Got mine done a few months ago. Had a 2024 model I took in there 3 times to address it and they said no. I gave up. Within spec. Never advertised as waterproof etc.
Took my 2025 in and just casually asked about it. One tech heard me and said wait, there's a new bulletin for that now. I'll take a look.
Addressed big difference. It still leaks but at high speeds while raining. I don't think I can avoid that but parked it seems waterproof.
Do you happen to have that bulletin number?
GasNah
Will
SoCal
Cybertruck AWD
I just had this fix done and seems to be working and from what I can see they tested for leaks after completion. I will test soon to confirm.
kpanda17
Just added it to my current work being done at the SC
Thanks
Great teamwork here
