Second truck with more scratches, scrapes, pitting(?), sounds and other small issues.
Tanquen
The first truck was delivered dirty with a good sized scratch that was found after paying while getting ready to leave, after some hand ringing I decided to refuse it. Six or so weeks later they had a second vehicle and I asked them to please check it carefully. After the second time talking to them about it, they then sent a picture of scratches on the front bumper. This wasn't as concerning as that can be easily replaced and they did say they would replace it.
After coming out to see the vehicle, it was, to their credit, much cleaner than the first one. There were more scratches and scuffs. Most every piece of plastic trim has scuffs or scratches on it.
Unfortunately, after having the vehicle for a couple of weeks I also noticed brown spots all over that looked to be some kind of pitting. The vehicle currently has 172 miles on it and around 60 of those are from picking it up. It’s never been wet since delivery and lives in the garage.
The pitting is mostly on the front hood. They look like little brown spots. So far I've only used water and a new microfiber cloth to take off bugs. But I then noticed these brown spots that could not be removed. On closer inspection, they actually look like erosions into the metal. I don't think they're the rust issue that some folks were having. It also doesn't seem to be rock chips. I've never heard anything hit the truck and I'm not sure what a rock chip would look like, but these don't seem to be that.
See all issue details below.
There is a creaking almost frog like sound while driving at around 30-35 MPH or so.
Creaking somewhere in the dash, not always there.
Ventilation fan is a little noisy on low (setting 2), little rattle or clunking sounds.
I also do not hear any lock sound. Now make a locking sound after the last Firmware update.
The manual says there should be a setting but I don't see it.
When the vehicle locks, the exterior lights flash once. To also sound a confirmation chime when Cybertruck locks, touch Controls > Locks > Lock Confirmation Sound.
Right side. Trim is a little high. The back ends of both sides are also high but it looks intended?
I was able to push this down and there was a click like it clipped into place.
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. Cwzqx7CG5UFPQOMX-zRhW02g4djDGGj5g1ANTbrawHmK5HcmtA
This is the front bumper pic they sent me before pickup but most all black plastic trim has a mark or two.
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. PwNZSClcQK1vsb5h25ylJnskGST2FOtTptawmLppb7_B5INcHI
Some trim seems loose. Front right seems solid but the same spot on the front left is maybe not clipped in.
Link to video of loose trim. Don’t forget to click play.
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. yR4WtelTndFtkqWT8GQzSgXnnkvX6fAYAbLsWP-g8MweQFNqRo
Rear Tailgate Light on the right side and marks at the top edge seem to be on or under a clear layer. May wipe off but not wanting to try anything but water and a microfiber cloth.
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. Klz53sMsrb_akVfcNvT4pAvvUP24vuVrg80kUMPk75Fl9t7-L4
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. b-RW9KMkS9shK5RXDe9YWq6IaxDIngwOufDPwBsHoGIi7remgI
Along the top edge.
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. ykyhbx6304YaW3pUFwjSd3XanFGkTn5kkPwrggdt2DMuix-w9E
Rear bumper. Smaller scratches.
Lower left under tailgate.
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. pdbGFW6R7ggIxztrFzNf1V6fQU1HC0ltolVOJb676iI_bkLkwo
Lower right side.
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. Alm5IMx1vkhgjI2dhagJVlW7atBtd3sW1druxugbPmBFX-aE-M
Passenger side, right front. More scuffs and not have been able to remove what looks like fingerprints. They took a picture of this one at pickup.
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. z7tUJY7vpu55YAZ2q612Dew6KHVpRmtGlfJ96qUXIacBjGseMk
Same part lower end by door.
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. ivKwnCVdJcTZqVY_rA5iu_8fR_AVILRW3QA0DjeLrsmYiLDJ-8
I did show this to the delivery person but I don't think he took a picture. Passenger side, right rear.
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. KpXjXSSTIzgPsthZFawJUWzEgKfUSLkHkpQiKKnhVGnwXTpvZs
Passenger side, right rear, lower.
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. 6BJt1kRIiEk-jlzWC2ISJtkBAsZ5YpT82JmVfL7SDlyjC97MFo
Driver side, left rear, lower.
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. 8547AU_Lm7aoV_u_t2cFi2qWKX-R5AH-alo05JMifjc8mpQoNI
White chalky stains all over the truck bed and tailgate and bed lining. Don’t change when washed with water and microfiber cloth. Some in the frunk too, but have mostly come off in the front trunk.
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. zN3IbPbqFkObUMJagYcYCiyLLsubjjyQ1BSrGkImFXdUNC61jk
Glue on edges of glass. Not that bad but is there a way to remove it without making it worse?
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. pkzZYGTuSZPTBumeIw3yabFnbUXqIL3irp0o3Up76IVS2zpqis
A handprint and a lot of fingerprints on the bottom of the tailgate, also on the hood. (Hope these just come off. What is best to try and remove these?)
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. _bogvhHhLhcA2nusWRIr5NCeJwqVvE1h51cVHAst0sCDJ0T77Q
There are a number of light scuffs around the truck. Not a deep scratch like the first truck but I'm guessing not easy to remove. They just pop out from time to time when walking up to the truck. The worst one is on the rear left.
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. 0yNBhztoymgKzkcT9IMuH8jPFTOTyES4pgEayzSPjJf2_-EFyE
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. jUIpCd_uzoUm2E6iRnnr5WCxCZCyeOMdtIpWm12QBmOxzZCLXo
Pitting? Not just rusting contaminants and not sure what to do about these or how many there are, they are mostly on the hood but are on the sides too.
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. d5YMFeYyZvJ4trKvYI04uCMeCwZnVRk8tQDCC331GvTJm4AqFU
Wrinkle like distortion in the left side of the windshield. It’s hard to photograph and it’s not a huge deal but distracts me sometimes. Looks like it’s between two layers of the glass.
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. 0SeTS_-7HqbYxCygDZHoemKugPJ7RP06zn5JDOOEMPgnIgwlqA
Dimples on the top edge of the white door trim.
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. F_qCcaqlStKKml9lhd5Mv7iOoylAMRD2QqPMPsx9BQGRk_S83U
Randomly, turning the sun visor down, the plastic drive selection housing comes off.
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. UVslhhjIpkVPV2wE0D7I7twwebm0UNIQpBsIOkWDCsWijzB_5Y
Small mark on dash, right of the display. I saw this at pickup but there was more dirt around it and it looked like it was coming off. It was just the dirt around the scratch that came off.
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. WZWE7XVs7-AgFfw6-42R934XPnqFiF1Y3Z0H97kdA5Al-j00Ik
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. KWLAWImQ3vz_nqJrldRZiQjELmMBVrPxNiwG-Inr5VmMF6FXv0
There are a few smaller ones that did not have dirt with the marks.
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. 8H69tTMpsTUAmplHXqGfXvSZ0eijCLocIgP7EdNuEpQgrVdnLg
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. HIXjGO2vPg28js8byTJ-WUjK7TCiy2HTwo-zcm4Q17JuXSdgus
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. gVf7AgcyEsN2xUPXxm0s1aVxzF8_bDinJoTCvj-grCWhVONVys
Small marks, glue(?) on the center console armrest.
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. Nl7i8ZEmrgdWUXnjrNPJXlWyrn8Exb-gxBYs3vKceIeABEqJzU
Scoundrel
Han
ts.la
Y / FSCT AWD
After coming out to see the vehicle, it was, to their credit, much cleaner than the first one. There were more scratches and scuffs. Most every piece of the black plastic trim has scuffs or scratches on it.
Unfortunately. After having the vehicle for a couple of weeks I also noticed brown spots all over that looked to be some kind of pitting. The vehicle currently has 172 miles on it and around 60 of those are from picking it up. It’s never been wet since delivery and lives in the garage.
The pitting is mostly on the front hood. They just looked like little brown spots. So far I've only used water and a new microfiber cloth to take off bugs. But I then noticed these brown spots that could not be removed. On closer inspection, they actually look like erosions into the metal. I'm not sure if they're the rust issue that some folks were having. It also doesn't seem to be rock chips. I've never heard anything hit the truck and I'm not sure what a rock chip would look like on the bare metal, but these don't seem to be that.
There is also a creaking, almost frog like sound while driving, creaking somewhere in the dash, proud plastic trim on top above the right side doors, a wrinkle like distortion in the windshield, what looks like dirt under the clear plastic in the tailgate light and a scratch in the dash.
This is the front bumper pic they sent me.
Rear Tailgate Light
View attachment 41950 View attachment 41954
Rear bumper.
Right rear.
Right front. More scuffs and not been able to remove what looks like fingerprints.
View attachment 41959 View attachment 41960
A handprint and a lot of fingerprints on the bottom of the tailgate. (Hope these just come off. What is best at removing these?)
Small mark on dash. I saw this at pickup but there was dirt around it and it looked like it was coming off.
View attachment 41961 View attachment 41963
View attachment 41964 View attachment 41965
Pitting? Not sure what to do about these or how many there are, they are mostly on the hood but are on the sides too.
View attachment 41966 View attachment 41967 View attachment 41968
For the "rust" spots, you should watch this video...
Rear Tailgate Light
Rear bumper.
Right rear.
Nor sure if it is the lighting but some of those look pretty bad, have you mentioned these to Tesla or just going to eat it because you want the truck?
Tanquen
Some good info but I'd like to see something from Tesla on what to use and how, for best results. Not sure they are removing the contaminants that are eating away the metal and then dirt will fill the little pits even if they don't continue to eat the metal.
mallenbrand
M
KS
2012 F150, 2020 Q7, Cybertruck
It’s not eating the metal. That’s surface contaminates rusting. It will not pit the stainless steel. Use liquid barkeepers friend and it will be smooth.
agordon117
Ohio
cybertruck foundation awd
You probably aren't going to find anything from tesla, so you can either take what the group here is offering or leave the marks as is.
You say they are pits, but we can't really tell from the images. Only if you cleaned them with barkeeper's friend (the spray bottle version, as it has no cutting agent in it) and the marks were still there would it be apparent to us what you are seeing.
Having said that, I can't believe the number of issues with your truck. what on earth are they doing between when it leaves the factory and is delivered at your showroom in particular, that is causing every single plastic panel to have scuffs and scratches?
Tanquen
I can try to get better pics but this looks like it's into or below the service.
Tesla Cybertruck Second truck with more scratches, scrapes, pitting(?), sounds and other small issues. 1711819602121-hj
Tanquen
I guess I'll get a magnifying glass and take a look but it sure looks like little pits into the service.
Do we want the liquid barkeepers friend with or without a cutting agent? The bottle I have for the kitchen is the liquid one with Oxalic Acid.
agordon117
Ohio
use without cutting agent. The stuff in the spray bottle. I think it's called "Barkeeper's Friend MORE". Then neutralize with water or windex, both seem to work but some swear that the tiny amount of ammonia in windex will ruin the stainless as if it's 350C at the time of application.
If that really is pitting, if you show it to someone at tesla, this is the first step they'd take anyway. So may as well find out for yourself. If they really are pits, there's nothing you can do to fill them in. All you could do is get a service center to do the refinishing technique and hope that it smooths them out or fully removes them.
Planet Earth
$59k CT delivered 6/26/26
Straight from Tesla…
1. While wearing gloves, apply a mild, citric acid cleaner with a sponge or microfiber cloth to evenly saturate the entire area of the stainless-steel panel. Tesla recommends CitriSurf® 77 or equivalent. The citric acid binds to and dissolves the iron oxide in the contamination, which can then be removed from the stainless-steel panel.
CAUTION
Follow the citric acid cleaner manufacturer’s instructions for proper use.
CAUTION
Citric Acid-based cleaners break down iron and other chemical components which may cause slight localized color deviation The process outlined here can be performed on entire panels or the entire vehicle to ensure consistent coloring of the exterior surfaces.
  1. Apply enough cleaner to cover the surface completely while minimizing dripping or pooling.
  2. Let rest for approximately 3 minutes, then remove the cleaner using a blue Scotch-Brite® Non-Scratch Scour Pad to lightly scrub and remove the surface contamination.
    CAUTION
    Do NOT use anything other than the blue Scotch-Brite® Non-Scratch Scour Pad to remove the cleaner. Doing so may scratch the vehicle’s surface.
  3. Remove any residual cleaning solution with water and dry the panel with a microfiber cloth.
  4. The cleaning solution may leave a white residue on plastic trim. This can easily be removed with isopropyl alcohol (IPA) wipes. Continue caring for and cleaning your vehicle as normal.
Links for purchasing:
https://www.amazon.com/Citrisurf-77-Stainless-Steel-Cleaner/dp/B01CIRIK7C/ref=sr_1_4?crid=1CALSVMQZSRXZ&dib=eyJ2IjoiMSJ9.J0F_6bb_AmS7ptNAf9Vj0sPkyiAsMJT7tboUxqqcn9V_ZYT9Lz0CDzuEUgVcrL-F.izRaJBjFSqU4O_lAq3WaO9cOedDN5qrJAP9rTyacHKY&dib_tag=se&keywords=citrisurf+77&qid=1711820720&sprefix=Citrisurf+77,aps,184&sr=8-4
https://www.amazon.com/Scotch-Brite-Non-Scratch-Scouring-Kitchen-Cleaning/dp/B09QNFB1P1/ref=sr_1_5?crid=1GOE49KGT3CSD&dib=eyJ2IjoiMSJ9.IZxlrB7_7gVcMEUzyRAGkAYSfsMAmWsFLdbPDiOf4AuGdPN_3GZxr-TOodit6MCXda1nyU0oIqqxOJLSDeSsVikO3CNAPAdj1FvA4a8CqhzAgd_HpMWxSg2dTyfxDjiRV-uuupeoB7wPYxGauXvUt7jlFY1lW2CvORynB2TsQ3DIhSqMWzzvOPqlm0NcLLrSJga9-H7J80rnsDDRiQ-9d_9ng011ObAJYcKciTeQ2W0ZgIWUNpKRNMA34yI427Of-sUjK8JU7oi9SVmlkiR3PqvKiykXqgAp6jCefAbTOl4.6a5zx09DkK2hT94seusNwaZcrQwcNahcDIPj17P0WzE&dib_tag=se&keywords=blue+scotch+brite+pad&qid=1711820811&sprefix=Blue+sco,aps,167&sr=8-5
Tanquen
Tanquen
Ok, the guy in the video said to use or that he did use the one with a cutting agent. Try the one without first and then the one with?
I now have started to schedule an appointment. I thought the did at pick up when they took pics of the other issues.
