SlegMD
- Apr 24, 2023
- Arizona
- Lexus
- Medical
What’s the size of the solar array? 49a is high and might keep your charging threshold from charging from solar. From my experience;
Turn it on and leave it alone, it does the job fairly well. My setup is only 12.5kw so if AC (summer) triggers charging the EV is null, typically lowers to 1-3kw. This is at 18a. I lower the charging amperage for demand charge and heat management.
Other option is I deactivate charge on solar (CS) and pull from the array and battery(PW3)with AC/house demands going as normal, battery (PW) remains ~80%+, then I deactivate EV charging to top off battery. This method manually prioritizes the EV where I’ll achieve the expected load whereas CS will not.
