Starlink mini set up & 3D print request!
J.Graham
BC
FS AWD & Model Y LR & 993
I finally pulled the trigger on a Starlink mini. Stuck it on the front dash with a strip of double sided Velcro and ran it through some mountain roads at high speeds over wash boards and through some technical sections that required extract mode with both lockers. The mini didn't budge, so I'm content with my set up at the moment. Still waiting for a USBC cord to tuck the wires away, but this held up perfectly!
The silicone case I purchased also came with a matte black sticker for the top of the dish which eliminates the reflection in the windshield.
All that being said, it would be great if one of you 3-D print gurus could make a silicone case with grippy knobs on the bottom that fits perfectly into the angle where the dash meets the cloth in the front windshield.
Tesla Cybertruck Starlink mini set up & 3D print request! IMG_6975
Tesla Cybertruck Starlink mini set up & 3D print request! IMG_6974
Tesla Cybertruck Starlink mini set up & 3D print request! IMG_6972
Tesla Cybertruck Starlink mini set up & 3D print request! IMG_6969
Tesla Cybertruck Starlink mini set up & 3D print request! IMG_6965
Tesla Cybertruck Starlink mini set up & 3D print request! IMG_6976
Fugue
Kentucky
Cybertruck AWD FSD, Model Y LR FSD
Tech Industry Grunt
Would you mind sharing a link?
J.Graham
J.Graham
BC
https://a.co/d/0djm8LKX
If your already having success with velcro could you not use this to secure top and bottom?
Probably but I like where its sitting now, at the edge of the dash. A custom case that sits right there and fills the space underneath with little nubs to grab the fabric would lock it in and be very sleek.
J.Graham
J.Graham
BC
Improvement to original install. I decided to cut 4 slits in the case and run the velcro under the mini so it's completely hidden. Turned out great and sits very solid on the dash. Also drilled holes at each end of the 1" slits before cutting the silicone. Thought about positioning the mini to the passangers side but chose the center of the dash for full exposure, better security (harder to reach in and grab it), and probably a little more stable when off-roading (although this thing doesn't budge!). Changed the 110 plug to a 16.4 ft usbc cable and routed along the dash to the pasangers side down the inside of the door frame to the foot sill and under the rear floor mat. Completely hidden cable. Small plastic pry tool came in handy!
Tesla Cybertruck Starlink mini set up & 3D print request! IMG_6981
Tesla Cybertruck Starlink mini set up & 3D print request! IMG_6980
Tesla Cybertruck Starlink mini set up & 3D print request! IMG_6985
Tesla Cybertruck Starlink mini set up & 3D print request! IMG_6988
Tesla Cybertruck Starlink mini set up & 3D print request! IMG_6989
Tesla Cybertruck Starlink mini set up & 3D print request! IMG_6990
mfqfgc
Nathan
victorville
Can you link the USB you used? And where are you plugging in to?
J.Graham
J.Graham
BC
I went with a 16.4FT usbc cable and tucked it along the dash down around the passengers side along the inside of the door jam along the floor to the back and plugged it in one of the rear outlets behind the center console.
Starlink Mini USB C Power Cable, 100W 16.4FT/5M Power Cable for Starlink Mini DC Male to Type-C Male Waterproof Starlink Mini Accessories https://a.co/d/0dxGgrRd
mfqfgc
Nathan
victorville
thats 45watts those back USB plugs have. think the one under the center console is 100 watts. Thanks for linking it. i will do the same. ordered
CyberT
Orange County, CA
Service Technician
Technicaly all 3 USB-C ports are 65w. But if multiple outlets are being used at the same time, then the power output will be reduced.
Tesla Cybertruck Starlink mini set up & 3D print request! 1771594079980-2d
Does the Velcro stick well to that dash covering? The loop side directly to the material?
J.Graham
J.Graham
BC
Yes it does! I was quite surprised. And I've put it to the test several times now...it doesn't budge!!!
(Insert me in Baja mode 95%R/5%F doing crazy doughnuts on rutted out open dirt area in the mountains behind my house) 😎🤘😝
