Think I have a PCS issue.
Thejm
Cybertruck Cyberbeast
All,
I noticed recently that my truck only charges at 24A on my AC home charger. I went into service mode and found this PCS code. I have seen similar people post similar codes on this forum but not this one. I scheduled a service appointment but it's not for 3 weeks. Does this mean that I most likely need a new PCS? Thankfully I only have 44k miles on it so it's under warranty. Any advice is appreciated!
Tesla Cybertruck Think I have a PCS issue. IMG_3069
JCERRN
J
Around
Yeah
All,
Possibly. Pcs is a complex electronic with many fail safes, redundancy and critical vehicle interactions. Hard to know if its a replacement fix without tesla techs looking into it but if you are having charging issues it will likely require replacement.
I would enter a ticket and ask a Service Center to perform a diagnostic at the very least so it's easily documented as a problem that started *before* your warranty expires.
ChiTownCT
OG Rivet Crew
Chicago
CYBERTRUCK
Did you notice anything out of the ordinary that may have caused it?
65SoYoLO
Keith
Long Island NY
2024 CyberTruck
Retired truck driver
Is it possible to try another home charger?
Thejm
Thejm
D
No, didn’t notice anything. Just that my home charger wasn’t getting to 48A like it normally does.
Ya I have 2 home chargers, one through FPL and the other through Tesla. Both charge at 24A and both are set to 48A.
SlegMD
Lexus
Medical
Probably be ready to take it in if you lose the ability to charge at home, regardless of appointment
CT425
WA
Cybertruck AWD Foundation
You can try a Supercharger if you lose the ability to charge at L2.
syburtruck
Matt
Cybertruck FS Cyberbeast
This is almost certainly a failing PCS. If it was me, I'd supercharge only until you can get in for service. Schedule it now as it's a part that has availability challenges from time to time.
syburtruck
Matt
FWIW -- When mine failed the symptom that I first noticed was 48A charging dropping down to 24A. The error message more or less tells you the problem, one of the two onboard Cycloconverters as failed.
Ivessm
Stew
PA, USA
Yes, Fill out your service request. The Mother Ship will reach out and verify and give you a listing of replacement items they will perform @ $0 cost because your still thankfully under Warranty.
There is another thread here that covers the PCS issue in detail. Just do a search on PCS and you'll find it. Good survey on that thread too that you can contribute to.
My appt is 02/16 to have mine replaced. Same symptoms as yours.
