Tonneau mystery- update mystery solved!
SanJoseNinjya
mikio
CyberTruck
I checked my CT when someone got a tonneau cover with different colors(mix of black and silver) on delivery, and found mine was all black. When I picked up CT at wrapping shop todat, my tonneau cover became mix of black and silver!!!, then when I got home, the tonneau got all black again. I can not figure out what happened to my tonneau,
Tesla Cybertruck Tonneau mystery- update mystery solved! PXL_20240228_232628674
Tesla Cybertruck Tonneau mystery- update mystery solved! PXL_20240229_021257239
wonder anyone got the same experience. this is like a magic:)
That is really odd, any chance the wrap shop flipped them over, or one is wet causing color?
Cold.Truth
Big A
Albuquerque, NM
2024 CT AWD, 1987 Carerra, 2016 Triumph Thruxton R
I.T. Project Management
Extra-special feature (for free!). ;)
edc
C
Tesla Model X, Y, Cybertruck
what the... that's crazy and its like perfect too so not like it rubbed against something
SanJoseNinjya
SanJoseNinjya
mikio
CyberTruck
no, I did not hear any sound like rubbing something... I will explore it again under the sun, but this is so mysterious.
kpanda17
talking tonneau, changing the topic slightly, how bad is the water leakage in?
If I put luggage back there will it get wet in heavy rain? can you store anything in the back and it will stay dry?
Derektsla
Derek
Greenville, SC
Cybertruck AWD, Model X
Entrepreneur
What is the cover made of? Are they discolored underneath when that happens? Are they warmer? Colder? Was this right after the tonneau was closed? Did it change back after being closed a while?
It’s so uniform across the slats. Trying to think of possible causes…
- temperature discoloration
- light reflectivity due to surface texture at certain angles.
- magic hidden solar panels.
- something affecting panels when it’s open and they are hidden.
That looks like the “racing stripe”, or the section that is neither rolled up inside the coil nor sandwiched in the rear wall. There were RCs at GFTX seen with a similar pattern. The area was exposed to dust or moisture or something, which cleared up as the unfurled cover was driven.
Tesla Cybertruck Tonneau mystery- update mystery solved! 1f8f450a-4365-4c83-8db4-43c74ca7d4d0-jpeg
LonelyCTfan
George aka "Katrina Georgina Wonder"
None Yet CT Foundation Ordered
Man of Many Hats
Is it possible that it's like a conveyor belt? Do we know exactly how it stores itself? Is it possible that we see both sides of the cover and one side is all matching and the underside is not?
Tesla Cybertruck Tonneau mystery- update mystery solved! 0809968c-2b62-47f8-b605-27bf39e16423-jpeg-
From the patent application
Wonder if there is some water, or oil in the lowest part of the storage area that when retracted soaks a few panels and makes them look different.
