Towing a 300lb trailer with 600lb cargo at 38F temperature
c4b3rTruCker
Cyberbeast Foundation Series
Cyberbeast Trip Report: Transporting a ride on Lawnmower first time pulling a trailer.
• Trip Overview: Traveled from the east side of Washington State to the west side with a trailer. Minimal traffic. 238 miles each way.
• Trailer Load: The trailer was empty on the westbound leg and carried 600 lbs on the return trip.
• Road Conditions: Clear weather with an average temperature of 38°F. Some rain and sleet through the cascades. I have All terrain tires.
• Energy Usage: The range was significantly reduced, requiring nearly 6 charges for the round trip compared to the usual 1.5 charges each way under normal conditions.
• Charging Pattern: Battery was charged from 10% to 75% each time
My range was less than half on this trip.
Does nearly 6 charges mean 5?
And does 1.5 each way mean 3?
So 2 extra charge stops?
What charge range do you normally use?
Aero and speed matter more than weight.
What did it look like?
scottf200
Western NC
X; immed family 3 & Y
What were the Wh/mi numbers each way please? Thx.
Tesla Cybertruck Towing a 300lb trailer with 600lb cargo at 38F temperature aQWKyH7
scottf200
Western NC
How can I pull up my previous WH data?
I thought you may have taken note of it or assigned it to a the A or B trip.
If you used a product like TeslaFI-COM then you could look back at this data at anytime.
eg a Nov 15th trip I took showing 2 charges and 2 drives
Tesla Cybertruck Towing a 300lb trailer with 600lb cargo at 38F temperature 3wdZ488
65SoYoLO
Keith
Long Island NY
2024 CyberTruck
Retired truck driver
you had to be flying. I got 175 miles on a 96% charge to like 11%. I don't remember the exact finish % but I was towing a 3200+ travel trailer. I was driving abut 60mph.
scottf200
Western NC
Were you on flat or going over a mountain?
Tesla Cybertruck Towing a 300lb trailer with 600lb cargo at 38F temperature MsLFF48
FYI, bike mode so the elevation graph below would show up.
Tesla Cybertruck Towing a 300lb trailer with 600lb cargo at 38F temperature fQMTHVX
65SoYoLO
Keith
Long Island NY
2024 CyberTruck
c4b3rTruCker
I averaged about 68MPH and now that I look at my load, the trailer is 800lbs with a load of 600lbs.
c4b3rTruCker
Yes, that was the exact route. It is only "hilly" for about 4 elevations and 4 descents after Yakima but otherwise the grade is pretty mild.
c4b3rTruCker
I'm going to sign up for this app and see if it is helpful. Thank you.
