Depends on wire type:Should I use 6AWG conductors for a 10’ run for the direct wired 60A breaker?![]()
@mongo has the correct answer.4AWG copper or 3AWG aluminum for 60a.
6AWG can certainly carry up to 65a, but you shouldn't exceed the .8 load standard, making 6AWG maximum standard is 65 * .8 = 52a max recommended for up to 100' runs.
If you were going beyond 100' run, then you'd have to go even larger than 4awg.
At least that's what a qualified electrician would do.
Hope that helps.
You'll be fine mentioned! 4AWD I hard to conduit, but I would expect it from a contracted job.Depends on wire type:
Individual THHN/THWN-2 in conduit: 6AWG 90C
NM-B (Romex) cable: 4AWG 60C (4/2+G)
https://www.cerrowire.com/products/resources/tables-calculators/ampacity-charts/
https://www.tesla.com/sites/default...ng/Gen3_WallConnector_Installation_Manual.pdf
Agreed! Is this for a charger?BTW, I would never use aluminum wire for charging a car (and the Tesla Wall Connector is not certified or rated for aluminum wire).
Thank you Tmeyer3 for your advice. It is definitely easier to bend 6AWG vs. 4AWG. I am going with Southwire 4/3 MC with 3/4” connector, 3/4” single hole conduit straps and a mc bushing. I used Sigma for cabling accessories.4AWG copper or 3AWG aluminum for 60a.
Hope that helps.
Thanks Mongo! THHN at 90C in conduit will pass inspection. I think EMT is way to go. But pulling THHN is hard without lube.Depends on wire type:
