What voltage does OBD port output?
If you use an obd power adapter on our trucks what voltage do you expect to see? 48v? Or 12v ish (around 15 I’m guessing)?
Up to 5 amps I’m assuming. So around 60w maximum draw correct?
Black306
Sacramento
‘26 PAWD CT | ‘23 M3 RWD
Measured 15.6v between pins 4 and 16 on mine.
Tesla Cybertruck What voltage does OBD port output? IMG_9137
Thank you
I wouldn't risk using such a port to power anything other than diagnostic equipment.
What’s the concern there? Was thinking just a 2 pin adapter. .Is that likely to precipitate error codes and such?
jimbaum
jim
Plano, TX
Cybertruck, Model 3
Baldyloxx
Earth
Is there another port location other than the left of dash?
...asking for a friend
So, the magnetic phone charger that plugs into the ODB port would not be a good idea? I was considering getting one since my phone gets too hot in the wireless charger.
correct, not a good idea. just spend the time and carefully route a long USB-C cable from one of your ports.
Fair. The main reason I want it is a 24/7 low wattage supply for an always on device.
I guess there are other ways to do that now with the “leave aux power on” software update.
My magbak chargers on the driver and passenger side of the screen previously went along the side of the center footwell to the back seat usb-c ports but now plug into an anker multi-usb-c charger which runs off the ac plug. The advantage is you can use as many as you want and get full power PD ports that are not split somehow.
Can charge as fast as your charger and phone or whatever else will allow.
TebisYang
OldYang
Jangsu China
Cybertruck Foundation
designer
It's best not to have output terminals higher than 20W. I have tried expanding wireless charging, which is around 14W and has not been a problem, but I really don't recommend it
Anyone here use one these regularly and nothing it’s a terrible idea? Just curious to hear opinions.
ActiveArch
Nubar
california
Also wondering the same, I just got the twraps charger and it’s been working fine but now I’m seeing this and sort of concerned.
resellpanda88
NY
Cyber Truck
I've had the obd to USB c plugged in for about a month now. No issues at the moment but not sure if it would do anything in the long run. Sent the vehicle in twice for service and no comments or feedback from the service team so far.
