What Wall Charger to Buy???
SwampNut
Carlos
Peoria, AZ
Rivian R1T, Zero SR/S, Smart
Geek
120v/12a gave me a bit of usage anxiety, but I only had that for about a week and we were using the car more as a new toy. I already had a welder outlet, so I just extended that and it's shared (only one can plug in at a time).
I used 120V/12 amps for almost a year with my Model 3. It's fine if you don't need to actually drive any distance or pre-heat the cabin on a winter morning to defrost the glass and reduce battery wear. I would not recommend it unless you are 80 years old and a big day is going to a doctor's appointment. That's a little exaggeration, but not much. Even just the defroster will draw 4 times as much electricity as the 12 amp outlet can provide, running down your battery unneccesarily before you even leave your house!
It's dumb to charge with 120 volts except in an emergency, get a real EV charging circuit installed, it's easy, we installed three of them at two homes and life is *much* better. That's my experience with a Model 3, a Cybertruck will be that times two! I recommend shooting for at least a 60 amp 240 volt circuit but if your panel has special constraints, 30 amps 240 volt would probably work adequately. Residential electrical infrastructure is under-rated with the world pivoting towards electrical everything faster than you can say, "charge me up".
Gas cans are out, big breakers are in.
SwampNut
Carlos
Peoria, AZ
Geek
I've never used the defroster at all. For half the year, we pre-cool the cabin before each drive, and that runs 4kW-6kW, highest when it's super hot of course. That's much more than the 120v charger provides, but then the pre-cooling only runs for 5-10 minutes.
6 kW for 10 min (1/6 hr) is 1 kWh. 120 V @ 12 A is 1440 kW. Thus the 120V charger will supply the energy necessary to precool your car in less than an hr.
SwampNut
Carlos
Peoria, AZ
Geek
120v * 12a = 1440 WATTS, not kilowatts. The maximum for a common outlet is 1800 watts, and Tesla will only use about 80%.
Cooling is using up to 6000 watts, as measured by the home energy monitor.
240v * 30a = 7200 watts
But of course, the car has a battery. So it can easily run the 6000 watts.
As you pointed out, the 1400 watts from the charger won't cover it... However, if it's plugged in, instead of using 6000 watts from the battery it'll use 6000 watts in minus 1400 watts from the charger = only 4600 are actually needed from the battery.
And if it only runs for five minutes, that 4600 watts is actually only 383 watt-hours. Which is about a mile or two of range. The charger will put that back into the battery in 16 minutes. (383 watt-hours divided by 1400 watts = 27% of an hour * 60 minutes = 16 minutes)
This is all done neatly since watt hours are, well, divided by an hour.
Adding a bit more than twenty minutes to your car's prep time - which the computer in your Tesla will calculate automatically - and the battery will be topped back up before you leave.
Correct.
= 1440W. Correct
OK
... but then the pre-cooling only runs for 5-10 minutes.
OK
= 60*1000/1440 =41.7 min. Correct.
What is it you are not understanding?
A year into it and I still haven’t gotten motivated enough to install a Wall Charger. Still on 120v for the Model Y.
But there will be a wall charger in place well before the Cybertruck gets here. I can deal with +50 miles per day with the Model Y, the Cybertruck will likely be +30 miles per day which is pretty limiting.
pagesix1536
Chris
Atlanta
2015 Nissan Leaf SL, 2014 Tesla Model S P85DL
I'm literally going to use the same 26-amp level 2 charger for the CT that I have been using to charge my Nissan Leaf with. Nothing crazy here.
Assuming it’s a J1772 connector that’s perfect. The Tesla one might be a little nicer if you squint hard.
Cybertruck Hawaii
Honolulu
Sienna
Nio doesn’t have any battery adapter, because they swap your battery, instead.
Cybertruck Hawaii
Honolulu
Sienna
It would be nice if you could have a sheet metal cavity in the truck area to stuff the charging cable and adapter so that it wouldn’t be exposed to the public to steal. Or have it plugged in from the inside of the trunk.
NIOs have chargers?
https://www.nio.com/nio-power
How would they charge at home otherwise?
How does it get to the wall if it's stuffed inside a steel cavity?
