- Oct 3, 2020
- Western Washington, USA
The battery ages in fairly direct proportion to the power provided, all other things remaining the same.A battery isn't considered cycled until it goes below 50.
And as pointed out, even at 350Wh/mi that's over 11k miles per plugged in 8 hours a day. That's more than enough for the average driver, even with some battery heating or cooling from the wall.
Cars on average spend 95% of the time parked. The median commute is 41 miles. Stay plugged in twelve hours out of the day on average and you have over 3k of extra miles charged per year, assuming no days off.
Don't underestimate the lowly Level 1 charge point.
This means each battery "cycle" is considered relative to the capacity of the battery. If a 100 kWh battery is dicharged and charged 10 kWh ten times, that is one "cycle" for general purposes.
There are a lot of small things like additional battery cycling and the fact that the car will be awake more hours when only using 120 volt charging that are less than ideal compared to more robust charging currents.
Less than optimal solutions can be made to work, they are just not optimal!
