ituner-HF
Andrei
Pleasanton, CA
Model Y, Cybertruck VIN 32xx
With just 1 watt I was able to reach Japan, China, Russia, Australia, Morocco, Spain and Denmark! Cybetruck makes the perfect ground plane for an antenna! Previous experiences with Model Y were not so good. Cybertruck is def. the quietest electric vehicle, RFI-wise.
I managed to install an HF and a VHF/UHF lip mount antennas on my Cybertruck by removing the aeroflap. Easy install. Still researching a way to route the coax in the cabin but my RG-316 cable just snakes easily through my rear door seal.
I used the Diamond KS-400 (heavy duty, 'super-gainer", lip mount), works like a charm, super stable. Select the 16ft coax option, 6ft is not enough. I used the 3/8x24 for HF and or UHFmounts for the rest.
Antenna: Little Tarheel (500watt capable) for 0-30Mhz, Comet for 144/440Mhz
Radio: IC-705, looking into installing an HF power amp as well.
Battery: floating battery for now, will try a USB-C 'trigger' for 15V, the IC-705 has no problem with 15V PSU, I used it before.
40m band --Not tested yet.
20m band -- S1-2 when truck stopped, S9 when in motion (not usable)
10/11m band -- S1-2 when stopped or in motion, almost no noise. CB radio (11m band) also works very well!.
144/440Mhz -- S1-2 clean, can be used in motion, no problem
NOTE: HVAC puts out a lot of noise on HF but not as much as on Model Y.
Here are some pictures, enjoy!
Ask me any question, I will be glad to help,
'73s
Tesla Cybertruck HF, VHF/UHF antenna (for HAM radio) install on my Cybertruck, works really well! 📶 1711660483417-jt
Tesla Cybertruck HF, VHF/UHF antenna (for HAM radio) install on my Cybertruck, works really well! 📶 1711660515760-7i
Tesla Cybertruck HF, VHF/UHF antenna (for HAM radio) install on my Cybertruck, works really well! 📶 1711660564424-e6
tbuck
Irving, TX
'73s
Very nice! Thank you for the report!
I am guessing you can probably fish that link down the back of the truck, under the bed cover, around the tonneau and back into the cabin. All of that sits on top of the battery, so there has to be a way to get it in there. How are you mounting the heads?
ituner-HF
Andrei
Pleasanton, CA
I hope I can find a way through the truck bed 'firewall" (bulkhead). For the radio mounting, I am still researching how to use the giant dashboard without drilling.... For now I used the cell phone charging tray it perfectly holds the IC-705 (but no phone) and occasionally there is a strong 13.56 MHz chirp from the NFC reader. :).
Tesla Cybertruck HF, VHF/UHF antenna (for HAM radio) install on my Cybertruck, works really well! 📶 1711665073562-o4
ituner-HF
Andrei
Pleasanton, CA
'73s
Additional note: The KS-400 lipmount is kinda expensive ($89), if you want an IDENTICAL heavy huty mount in stanless steel (has much better chassis ohmic resistance), buy this one, it includes a VHF/UHF high gain antenna ($35 for both!)
PeterOT
Peter
San Jose, CA
2019 Model S, 2023 Model Y, Cybertruck
Thanks for the report. I'm hoping to put my 7100 in my Cybertruck when I get it.
M0unt41nm4n
Durango, CO and Moab, UT
'73s
Very nice! Also nice to find another Ham in the forums. I have a Yaesu FTM-400XDR in my Jeep as I use the APRS for GPS tracking and getting SMS’ to the family when I am in the back country. That IC-705 looks nice… I have my general ticket but haven’t even played in HF. Thanks for sharing… I was wondering about where/how to get an antenna on a CT and where to tap the power.
CarMan ElecTruck
Other Earth
LeftFoot RightFoot
…I’m surprised you actually need an antenna. Already a whole lotta tin rolling everywhere you go…
looks good. Moon Buggy
ituner-HF
Andrei
Pleasanton, CA
LOL, Yes! Even with the whip disconnected I can still receive signal... The other half of the dipole is the Cybertruck body!
WHIZZARD OF OZ
Ivan
VW Up!
Electric Wheelchair Builder
'73s
Looks like one fine remote control car!
When l was 16, l bumped into the creator of a '74 lime green 4 door HQ Holden in the back streets of Springvale where l said 'there is something special about this car'.....he demonstrated how the car was capable of 'self-driving'.
I can share that when he opened the engine bay, boot and interior , that thing was cram packed with '70's technology. He said it cost about $50K to build.....back then a ton of cash. Can't wait to see the CT 'self-driving'
I wonder if Elon's mind is so bored without new things to focus on that he has designed the Cybertruck to multi-function as the perfect land-based version of AWACS, like a remote electronic surveillance platform. o_O
Probably just a happy result of the other design considerations (like corrosion resistance).
I'm curious what were the main considerations with regard to deciding upon a left or right side mount.
Also curious why all the lines appear to terminate somewhere around Vancouver, BC. while your profile says you live in California.
