greggertruck
g
Zimbabwe
www.twitter.com
Dual-CT
NEWS: An international Tesla patent filing for a Cybertruck power tailgate mechanism was published today. The patent states it could be operated via a smart phone or wireless key fob.
Tesla Cybertruck Cybertruck Power Liftgate Patent Published -- operated by smart phone or wireless key fob Tesla Cybertruck power liftgage patent
Tesla Cybertruck Cybertruck Power Liftgate Patent Published -- operated by smart phone or wireless key fob Cybertruck power liftgage patent
DETAILED DESCRIPTION
[0055] Generally described, one or more aspects of the present disclosure relate to power systems for opening and closing hinged closure panels, particularly the tailgate of a vehicle. Power tailgates often require complex systems involving a plurality of expensive components (e.g., sensors, mechanical and computer components). Further, known power systems can be bulky which can limit the ability to efficiently and compactly package the system within the vehicle.
[0056] Embodiments disclosed herein can provide advantages over such power systems. For example, in certain embodiments, the power system can significantly reduce the number of required components. This reduction of components can significantly reduce the supply-chain overhead, installation time, and cost. The system can have an improved reliability due to, for example, the reduction in components. A power system can be advantageous in overcoming adverse weather conditions such as when an ice bridge forms between the tailgate and the truck bed. Certain embodiments of the power system disclosed herein can break the ice bridge formed between the tailgate and the truck bed. For example, the user can simply activate an actuator of the power system to free a tailgate that is frozen to the truck bed.
[0057] In certain embodiments, the power system can ease assembly with the vehicle. For example, in certain embodiments, the actuator of the system can comprise a plurality of sockets while the vehicle and the crank arm each comprise a ball configured to be disposed in one of the plurality of sockets to ease assembly.
[0058] The actuator can be mounted to the vehicle in many different arrangements and configurations. For example, in certain embodiments, the actuator can be mounted vertically. In other embodiments, the actuator can be mounted horizontally. In still other embodiments, the actuator can be mounted at any angle between a horizontal mounting and a vertical mounting.
[0059] In certain embodiments, the power system can have a lower mass and lower cost than known power systems. A lower mass is advantageous since it improves, for example, a vehicle’s range. The characteristics of the system (e.g., size, weight, pressure, materials, etc.) disclosed herein are only exemplary and do not limit the scope of the disclosure.
[0060] In certain embodiments, the power system is hidden between panels of the vehicle (e.g., tailgate, body) resulting essentially in an invisible integration with the vehicle. For example, the vehicle can comprise an outer panel, an interior panel, and an inner space between the outer panel and the interior panel. The actuator can be mounted in the inner space. For example, the tailgate can comprise an outer panel, an interior panel, and an inner space between the outer panel and the interior panel. A counterweight member can be mounted in the inner space.
[0061] In certain embodiments, the system employs a torsion spring in combination with a compact, low power, low mass actuator. In certain embodiments, the system employs a torsion rod in combination with the compact, low power, low mass actuator. Of course, the disclosure is not limited to employing a torsion spring and/or torsion rod as the counterweight member.
[0062] While the power system disclosed herein is described in the context of opening and closing a tailgate of a truck or SUV, the invention is not so limited. Embodiments of the system described herein can be employed in the place of any power system or linkage that is intended to open or close a hinged panel. For example, the system can be employed as part of a vehicle storage compartment mounted in the truck bed (e.g., a truck bed storage drawer or box) or as part of a cargo-hauling system dimensioned to fit within the bed of the truck. Of course, the system is not limited to use with trucks or SUVs and can be employed with any type of vehicle.”
Zooom, enhance….
Maybe powered by the compressor used for the suspension?
Tesla Cybertruck Cybertruck Power Liftgate Patent Published -- operated by smart phone or wireless key fob 1687482088436
The image is a bit confusing because it shows the piston is 2 positions at once. It shows the extended position behind the compressed position and the lever it controls is also sort of in 2 positions at the same time.
The
Since most modern trucks have such a system now, Inwas curious to see Tesla’s take on the claims and embodiments in the patent.
Some relevant bits extracted and highlighted below:
Paradox
2023 Escalade ESV Platinum, CT TriMotor FSD
No more tailgate ramp?
I’m thinking they’ll offer up some add on, extra cost modular ramp that’s Tesla/Cybertruck branded but I wasn’t holding my breath that the ramp built into the tailgate was making it to production. If it does though and they can pull it off, I won’t be complaining.
CyberT
Orange County, CA
Service Technician
I’m thinking they’ll offer up some add on, extra cost ramp that’s Tesla/Cybertruck branded but I wasn’t holding my breath that the ramp built into the tailgate was making it to production. If it does though and they can pull it off, I won’t be complaining.
Im thinking they will offer it as standard but down the road like they did with power trunk/frunk with the model 3
Diehard
D
U.S.A.
Holly crap. If CT is coming out like this (pass through), I will definitely get me one:
Tesla Cybertruck Cybertruck Power Liftgate Patent Published -- operated by smart phone or wireless key fob 1687484144970
don’t tell me it is a light reflection. Let me enjoy this.
Edit: I meant mid-gate.
ÆCIII
Interesting that the Cybertruck in the patent illustrations is the Alpha prototype and not the latest Ăźeta ones we've seen, so @Diehard, you'll have to enjoy the light reflection realizing that as well. :)
This likely means this patent has been in work for quite a while.
- ÆCIII
greggertruck
greggertruck
g
Zimbabwe
www.twitter.com
Dual-CT
Since the patent shows it....
The gate ramp was going to largely being unused. That ramp would weigh a TON and also create manufacturing expense, to be largely unused.
I've mentioned this before, but not so directly.
greggertruck
greggertruck
g
Zimbabwe
www.twitter.com
Dual-CT
- ÆCIII
Patent probably dates back to 2019/2020.. There is just finally a publish date. Meaning they should prob be out by now lol
website update in 3....2.....
Patent was filed last year
Nonetheless, Tesla hasn’t used a single non-alpha schematic for these sorts of things
Even Q1 of this year Tesla’s own shareholder materials RE 48v architecture used the alpha:
Tesla Cybertruck Cybertruck Power Liftgate Patent Published -- operated by smart phone or wireless key fob D34BD253-B7C3-4513-BB02-930CD5EA2634
Zooom, enhance….
The
I don't see any air lines in. And that seems to be for the flat and slanted position!
That would allow for the ramp position they had on stage.
*bounce* *bounce*
That was my favorite thing they showed at the unveil.
SolarWizard
MB
Based on this drawing theres no chance a ramp is coming BUT what I do see is a hinge design that could open as much as 120 degrees. Im not sure if the clearance with the bumper exists but this appears to have the capability to not only lift the tailgate but also move additional weight.
im gonna make a prediction that they intend offer or make available for the aftermarket what would be the equivalent of a Tommy Gate
either way its going to be able to do something that at least I have not expected and this action could be very compelling to tradesmen
