PATEL
FL
Cybertruck & BMW M3
First real life look at the 20" Goodyear DuraTrac Tires / Winter Tire Package mounted on the Cybertruck -- posted by @Dufly
Link to winter tire package: https://shop.tesla.com/product/cybertruck-20_-cyber-wheel-and-winter-tire-package
Tesla Cybertruck 20" Goodyear DuraTrac Tires (Cybertruck Winter Tire Package) First Installed Look cybertruck winter tire package wrangler duratec RT tires
Description
Cybertruck Cyber Wheel and Winter Tire Package provides improved traction, stability and braking efficiency in conditions under 45°F. This package is Three Peak Mountain Snowflake (3PMSF) rated for areas that require winter tires and offers all-terrain capability for an improved off-road experience and improved toughness.
Includes:
  • 4x Cyber Wheels
  • 4x 285/65R20 Goodyear DuraTrac Tires
  • 4x BLE tire pressure sensors and nuts
Tesla Cybertruck 20" Goodyear DuraTrac Tires (Cybertruck Winter Tire Package) First Installed Look 1990599-00-A-1-01
Tesla Cybertruck 20" Goodyear DuraTrac Tires (Cybertruck Winter Tire Package) First Installed Look 1990599-00-A-1-03
Tesla Cybertruck 20" Goodyear DuraTrac Tires (Cybertruck Winter Tire Package) First Installed Look 1990599-00-A-1-02 (1)
Jack27
Randy
None
IMO the side wall looks 100 times better than the ATs. Way beefier. Had they been an option I probably would have stuck with my stock rims and these longer then I did with the ATs.
Zane Edwards
ZMAN
Audi R8, BMW 4 Conv. MB GLS, Tesla CT AWD
Exec
Definitely looks good and capable!
TexasRaider
JR
Denton
Cybertruck + MS
Civil
I don’t understand this post. What does he mean by first real like look? (These look like factory pictures and information..besides the initial photo.) Who is Dufly? Ha
RickJ19Zeta8
Wisconsin
Could someone who is more knowledgeable than I am do a quick summary in comparing these with the stock OEM AT tires?
The OEM AT tires have relatively shallow tread depth and minimal snow siping. The tire and compound is biased in design for dry traction performance,
, low rolling resistance. At the expense of tire life, wet and snow performance. The tire is part of the reason the beast can pull of a 2.6 0-60 on “AT” tires.
The Duratrac tires is designed for mud, snow and more off-road performance. It has more snow siping to help with winter traction. At the expense of noise, dry traction, cornering performance.
Neither is a dedicated winter tire, which maximizes snow and ice performance at the expense of every other metric.
If you do nothing but highway driving and city commuting. Get the Scorpian AS tire. If you need to do some light off-roading, hunting on logging roads, or just like the look, get the AT tires. If you live in a snow state, know what it means by “mud-season”, and live or regularly drive on barely improved gravel roads, get the Duratracs (which will work year round).
And if you live in a mountainous snow state, Northern Midwest/ Canada. Probably go for a dedicated winter tire. And one of the others for the other seasons.
2blentendre
NYC
Tesla Model 3 LR (Black/Black)
<3
This is extremely informative. Bookmarked. Thank you so much.
I mostly agree with everything you wrote. With more experience on the Duratrac Tires I can say the OEM AT tires are better on all hard surfaces, wet or dry, with the exception of ice, wet leaves, and puddled water (which isn't really a hard surface). The OEMs are also surprisingly better on cold, wet roads, at least down to 38 degrees F.
The DuraTracs are mostly better on soft surfaces, with the exception of loose gravel and almost certainly deep dry sand where the OEM AT tires will outperform.
The efficiency hit has shown up with an obviousness that is impossible to not see. I didn't see it at first because I believe on my highway drive home from the install, the trip computer hadn't recalibrated for the smaller diameter (so it thought I was covering more ground per kWh than I actually was). At some point it must have recalibrated, and the miles/kWh dropped rather precipitously. It's too soon for me to accurately quantify it, a wild ass guess would be 10%.
Du Fly
Shawn
Central Washington
2024 Cybertruck AWD
Sr Supply Chain Manager
They grabbed it from my Twitter post :)
