- Gus
- May 22, 2021
- Austin, TX
- 1981 DeLorean, 2024 Cybertruck
- Occupation
- IT Specialist
There are two factors of cell degradation: discharge cycles, and the passage of time (“calendar” degradation). When simply resting, the cells degrade, in proportion to state of charge (SoC). Higher SoC leads to greater degradation, but the relationship is not linear, with a steep increase above 80%. Around 50% would be best, even lower if storing long—term.
Tesla will warranty a pack that degrades below 70% capacity, but you would be hard-pressed to hit that if you tried. So charge to 100% if you feel you must, but I think you’ll soon find it unnecessary.
I’ll likely set my charge point to the lowest of 50% for daily use, and go higher as needed.
