- May 27, 2024
- SE Michigan
- Cyberbeast
The charge limit was set to 80 and the vehicle had charged to there.ok wow ive never noticed that but im not charging at home neither only at a supercharger. So your saying your battery set it to 72% and then you manually chsrged it for 90 more minutes and precondition got it to 80%?
also well the CT reach a full 80% charge when the weather breaks and gets warm again?
Then the temperature dropped and time passed.
So the pack was at 77% with a 5% cold derating and the UI showed 72%.
I activated climate control and 90 minutes later, it had added 3kWh net to the pack to get it to 80% with 1% cold offset, so reading 79%.
So it was always charging to 80%, but that doesn't account for cold adjustment and the UI won't necessarily read 80%. Same deal with Superchargers.
