carsly
- Vin
- Dec 13, 2023
- Princeton, NJ
- LR Defender, CT AWD
could make it worse. The ceramic coating is a thin, hard shell that isn't as hard as the steel underneath. So the brush against steel is one thing, but the brush will now scrape on something harder than the brush - which sounds good - but the other side is the brush is now pushing ceramic particles into your steel with pressure applied - that feels like it would be a net negative unless you believe the ceramic coating to be completely impermeable. It might help with shedding soft leaf rubs but twigs and branches will go the other way of adding insult to injury.I drive through brush which leaves scratches on steel. I suppose ceramic won’t make this any better then?
Seems to me like PPF, or even plastidip oddly enough, might be better suited to your needs. When it gets too chewed up you peel it off and apply a new section.
