Cleaning - BKF not working -scrub harder?
Cyberjam
Stotnova
CT
FS AWD named "Jerry", Cyberquad & mini-Hummer EV (grandkids)
Retired/sometime Rockstar
If you read the post I was replying to, he was adding Windex to Bar Keeper's Friend:
Windex is for glass and fingerprints. It doesn't help (and actively interferes with) cleaners other than surfactants. As Cybergus says, mild acids grab the free iron that may start rust crystals.
I prefer a low sudsing biodegradable surfactant and or isopropyl alcohol.
Spot cleaning ≠ rinsing a steel cleaner.
PS, some of you guys need to start asking the person who gets the spots from your shirts how different cleaners work.
Hi, Crissa. I appreciate your insights into the stainless steel finish. I have had great success removing fingermarks by using a spray bottle with water, adding about 10% white vinegar, and then wiping it up with a paper towel. No streaks. To the extent you would know, could this solution harm the finish? It seems pretty innocuous but I would like a second opinion. Thanks!
big.garcilla
Jay
Northern NJ
S 2016.5 Cybertruck 2024
hi, I'm lost in reading all this.
I was told at the dealer to use BKF, i read that i should use the liquid.
i am using bkf soft liquid.
I did my frunk and it is very shiny, a few markings that didn't go away. I rinsed with a bucket of water (is that enough water?) and then wiped with a towel.
i also did a spot where bird droppings had fallen. It is a differnt shard of silver now then the rest.
In simple terms. Is this right ? or am I messing up.
thanks (ignore my other newb post).
Kindest/jesus
Tesla Cybertruck Cleaning - BKF not working -scrub harder? bkf
Tesla Cybertruck Cleaning - BKF not working -scrub harder? tesla-ct-hood
No, vinegar shouldn't harm anything at 0.5% strength.
Kindest/jesus
You will want to soak the marks in neutral suds, before you use barkeeper's friend. Bar Keeper's Friend isn't designed to remove oils or debris except mechanically. Then once you have the oil marks off, use the Bar Keeper's Friend. And yes, it'll make the stainless shinier.
If the oil marks weren't removed before you do a more general wipe, you'll get shadows like that where they were. And you'll have to do it again.
In the case of little dots like that, you may need to let it sit a bit more, applied with a swab... Remember, it's only lightly acidic so it takes time or mechanical action to speed things along.
PS, I'm remembering this from having cleaned many a professional kitchen; trying to match finishes was not something I have ever really done ^-^;
Good luck!
Bothwalien
Utah
Cybertruck, 2022 Model 3LR
"Bar Keepers Friend More" spray has the same ingredients but without the micro-abrasives as in the original powder and liquid. I think it's less likely to cause unintended marking, especially if you use a microfiber towel for application. I didn't have to use anything highly abrasive to get the spots and marks out.
Sandman1962
Sel
Model S , Model X
I used the liquid BKF on those pesky rust spots (at least it looks like rust ) that remained even after the lauded Sprayway glass cleaner. I brush lightly with an old soft bristle toothbrush. In merely seconds, the spots were gone. Wiped away with a little Windex (could have been just water too, but too lazy). Minimal pressure on the brush and very little BKP (very little).
Tesla Cybertruck Cleaning - BKF not working -scrub harder? IMG_4610
Tesla Cybertruck Cleaning - BKF not working -scrub harder? IMG_4611
Tesla Cybertruck Cleaning - BKF not working -scrub harder? IMG_4612
Tesla Cybertruck Cleaning - BKF not working -scrub harder? IMG_4613
Cyberer
KK
Omaha
2014 S, Multiple Classics
Cars
As Homer Simpson once said to Bart: “If something’s too hard, stop trying.” ?
wabi-sabi.
tmeyer3
Trevor
www.meyerwine.com
Computer Scientist, Vintner
Iron-x, spray on. Rinse and done
