Sposborn
- Oct 21, 2025
- Indiana
- 2024 Cybertruck AWD; 2025 Model Y Performance
It would make sense since FSD could be blinded by the wash fluid and cause problems at on demand rinse. FSD seems to just do a rinse while taking over so seems like order of operatikns thing where other cameras may take over while it rinses at first. Idk.Maybe this is how both the sise and rear should be. I had no idea you couldn't wash front camera in fsd. Seems like a flaw
“Unless you put your car in Park” doesn’t seem right. You’re telling me if I disengage FSD and then click the button manually it’s disabled until cycling park and drive and you can’t just renable FSD after?I have the rear washer installed and it's awesome.
Just a tip - I installed it to my main wiper system instead of the front camera washer (if that makes sense).
You can't use the front camera washer when FSD is engaged which makes this solution almost useless unless you put your car in (P)ark. So, instead, I installed it to my main washer system to wash both my front windshield and rear camera system at the same time.
Worst case scenario, if you change your mind or want to revert to factory, you can repurchase/replace the rear tail gate for $1,800 USD and replace the T-fitting with with a L-fitting. No harm, no foul.
I'm 99% sure It does not void warranty - no one at my service center has ever said anything nor voided any warranty work.
