Cyberbeast issue message: “Air suspension unable to raise” and “Air compressor temperature above operating..."
DeadSetElectric
Marc
Took a roadtrip from SF to SD yesterday and got two warning messages on my screen.
“Air suspension unable to raise” and “Air compressor temperature above operating…”
Service appointment is Thursday; just curious if anyone else has experienced this.
It looks like the rear suspension might be blown as the wheels are closer to the fenders on the rear than the front.
VIN #159, build date 02/24, delivery 03/24/24
Tesla Cybertruck Cyberbeast issue message: “Air suspension unable to raise” and “Air compressor temperature above operating..." IMG_4363
Tesla Cybertruck Cyberbeast issue message: “Air suspension unable to raise” and “Air compressor temperature above operating..." IMG_4366
mark555055c
Buffalo, NY
The only time I've seen this is on a couple videos where folks were testing the air suspension, raising and lowering a lot in a short time. The message went away after a short rest.
In no change after letting it rest for 15-20 min, then a service appointment is the way.
96Kopper02
Iowa
Tesla Model S
Physician
Were you raising it up and down over and over before the message appeared?
FutureTruck
GA- USA
Tesla MX P, Lucid Air GT
Compressors generate a lot of heat, if you were going up/down a lot might do it
DeadSetElectric
Marc
It was in Chill mode the entire drive. Didn’t touch anything from the suspension settings. Happened like 2 hours into a 9 hour drive. It’s still giving the error codes today. So it’s had time to “cool down” and like I said, haven’t even messed with suspension. I just start driving and that’s the warning. My guess (hope) is it’s a loose connector that just needs to be tightened.
tlc5432
Tim
Los Angeles, CA.
Cybertruck (ordered), Model X, Model Y
Architect
I have had this issue a couple times on my 2016 X. It will sometimes self correct, although it once had a slow air leaks which they tracked down and replaced a hose. Annoying but easy repair
#5699
Azorian1
Carl
San Jose, CA
2004 F150, ChevyVolt, Porsche 914, 2024 Cybertruck
Engineering Program Manager
We ran into this while 20-30min in off-road mode with 4 adults in the truck and some luggage with tonneau cover closed. It went away after sitting for a couple of minutes. The service people said it was just a warning but I need to try it again. I hope the air compressor isn't that weak.
DeadSetElectric
Marc
Oof I don’t like that. I plan on overlanding and off roading with over 2,000lbs payload on a regular basis. Service is replacing the right rear air spring module now so hopefully that fixes my issues. I like the idea of air suspension but not if it can’t handle regular truck stuff.
Nicko
Nicko
Rockland County, NY
Tesla S, 3 CyberTruck Foundation, Porsche 911 C4
I also got the error that air compressor temperature is above the operating limit, raising suspension is temporarily unavailable. I have a Tesla service call tomorrow. I'll post an update when I get some answers.
DeadSetElectric
Marc
Sorry to hear you’re having issues! They replaced the entire air module on the rear right side. Pretty quick fix and I haven’t had any issues since.
akenis
Andrew
FL, USA
23 MYLR and (Apr-Jun CT AWD)
Pilot
I think one of the hoses on mine popped off. Load hiss. Stick at 7.5" height.
Service manual says to do push and pull test on Voss fittings. I think they missed one in Austin.
Tesla Cybertruck Cyberbeast issue message: “Air suspension unable to raise” and “Air compressor temperature above operating..." IMG_0455
Steve
Denver, CO
Battery Manufacturing
My issue is similar and indicating that it may go away on the next drive, but after 5 tries and multiple soft resets, the problem persists.
From the Service menu the fault is more clear. See images.
Tesla Cybertruck Cyberbeast issue message: “Air suspension unable to raise” and “Air compressor temperature above operating..." Main Screen Fault
Tesla Cybertruck Cyberbeast issue message: “Air suspension unable to raise” and “Air compressor temperature above operating..." Alert Log
Tesla Cybertruck Cyberbeast issue message: “Air suspension unable to raise” and “Air compressor temperature above operating..." Alert Description
I've put in a service ticket, but the earliest they can look at it is over a month away (July 31).
I'm thinking of possibly disconnecting the power to it (or the entire MV system) as shown in the service manual, but I'll wait a bit longer to hear from Tesla Service.
Diveflyfish
James
Wisconsin
2024 CyberBeast 2011 BMW 335d
Dentist
Yes I had this happen. Service replaced the Manifold. Upon driving back home it failed again. Return trip to the SC and two days of diagnostics, the pump itself had failed. One question I had is what if there was a bladder defect that while the bladder is stationary against the SS cylinder, no leak, but upon dynamic driving the defect would open enough to allow air to leak and thus prompt an overuse by default of the compressor to keep the air reservoir filled? Perhaps the best way to check this would be to submerge the suspension under water and cycle the heights......... one more reason to have "Boat Mode" and HD door seals!! Hopefully the new compressor will fix issue. The Tech noted the area had compressor oil around it so for sure it failed........ but Why is the critical issue. The weak link is? Bladder or other? Cheers.
herrjon
Jon
New Mexico
F150 FX4, Hybrid Escape
Electrical Engineer
What was the final verdict or fix?
Thanks,
Jon
Jack27
Randy
None
I would check the lines make sure nothing popped off
Is it possible that because your change of speed allot your compressor got to hit ? Because I just noticed when going over 80 mine will drop to low mode then back to medium .(total guess) Have you tried a hard reset. ?
