Cybertruck camper drawings
pumpkin curry
Korea busan
CT Dual Moter AWD
Cybertruck seems to have the advantage of using various camping equipment.
Therefore, I designed a truck camper that can be mounted on a Cybertruck.
The height of the bunk bed has been considered so that there is no discomfort from touching the head to the ceiling when a man sits on the bed.
I hope this drawing will be a reference to those planning to install the Cybertruck camper.
I have attached a pdf file so that you can view high resolution drawings.
Tesla Cybertruck Cybertruck camper drawings C1
Tesla Cybertruck Cybertruck camper drawings C2
Tesla Cybertruck Cybertruck camper drawings C3
Tesla Cybertruck Cybertruck camper drawings C4
Tesla Cybertruck Cybertruck camper drawings 1-Cybertruck camper(Ext)-20210221
Tesla Cybertruck Cybertruck camper drawings 2-Cybertruck camper(Int)-20210221
rr6013
Rex
Coronado Bay Panama
shorttakes.substack.com
1997 Tahoe 2 door 4x4
Weight balance appears rear biased. Front overhang is correct using â…“:â…” rule. So will CT 4door be very light on the steering axel with the slide-in weight aft? IDK
akia123
Curt
Phoenix az
Chevy impala
wow this is really cool. i been looking at truck campers trying figure out how they would work. thanks again for the drawings.
VI Tesla
David
Nanaimo
Model 3, Cybertruck
Not a camper but this is fifth wheel I'm rebuilding to tow behind my CT. Apologies for the rough render haven't figured out how to make compound curves on trailer.
Waiting on final specs so I can add appropriate lift to camper.
BrandZing
Rick
brand marketing
Your camper design doesn't work with the sharp angles and cutting edge design of the CyberTruck. This camper design looks way too out dated. A camper for the CyberTruck needs to look like it was specifically designed by Tesla to fit the CyberTruck's style and futuristic design.
rr6013
Rex
Coronado Bay Panama
Like how this render innovated by raising roof height over 5th wheel, hinting at Alpine windows and showing possibly widening at the camper-5th wheel transition with glass. You are already towing a brick anyway so taking license is cool.
Firetruck41
Ben
SW Washington
For real life a travel trailer does not need to match a cybertruck style/design.
I don't think it needs to match the style of the Cybertruck, I'd much rather have form follow function. It would be nice to have it as aerodynamic and light as possible, but I'd rather have standing room, storage space, good sized tanks, efficient layout and access, a good "floorplan" and other considerations, way before trying to match the style/angles of the cybertruck. It also has to be buildable economically enough for the market. Have you spent much time in an RV/travel trailer/camper?
The Cybertruck is deflecting the air around it in a specific way, so the trailer should react to that in its design.
Dids
Les
Massachusetts
04 Tacoma, 23 Cybertruck
Self
The overhang being off the roof seems unnecessary for the Cybertruck. The reason for the gap over the cab for traditional frame vehicles is so that the cab can move independent of the bed. CT is more ridged. Perhaps you could take advantage of the peak attachment point by having the overhang follow the roof line?
pumpkin curry
pumpkin curry
Korea busan
CT Dual Moter AWD
I think the overhang off the roof is necessary not only in the conventional truck camper, but also in the CT camper. See the traditional truck camper below. The overhang can be externally designed to follow the roof line, but the function of the overhang should be internally flat as a capover bed, so I don't think the overhang needs to follow the roof line.
Tesla Cybertruck Cybertruck camper drawings C3-1
pumpkin curry
pumpkin curry
Korea busan
CT Dual Moter AWD
I've already tried the interior design.
See the interior drawing of this post.
