Cybertruck charging problems since operating system 2025.32.0
DuaneSql
Duane
norfolk virginia
Ram
Since Cybertruck operating system update 2025.32.0, I have had charging problems. I took it to the dealer and they replaced my mobile charger, but I am still having problems. The charging problems improved a little when I updated to 2025.32.6.
It won't remember to default to 9Amps, I have to watch it default to 48 Amps and manually turn it down in the app to 9 Amps everytime. This problem started with 2025.32.0
I believe the charge amps setting is location-specific. Make sure you are parked at your charging spot when you set it (presumably you have your "Home" location set). You might also have some GPS inaccuracy if the view of the sky is sufficiently obscured.
esqtom
tom
atlanta
Darlene
Depends on the day
I was charging yesterday and went to a restaurant nearby and I had a return to the truck because it stopped charging and had to be reset on the dash screen.
Why are you turning the charge speed down to only 9 amps?
