- May 27, 2024
- SE Michigan
- Cyberbeast
I'm pretty sure the three images I posted were all precollision, but these two definitely are (and all removed iPhone shifts):Watching the original 4 second video, I think you will see this is not the case. Put your cursor on the car up by the bridge and play the video. You will see there is no appreciable side-to side motion until impact happens.
This is also one more way to verify the way the nose suddenly rose due to acceleration and remained there until impact.
I appreciate you looking at this from a fact-based perspective, and trying to find an alternate explanation, that doesn't require a sudden acceleration, but I think if you examine this theory more thoroughly, it doesn't hold together.
One method to examine the possibility of phone movement creating the illusion that the nose suddenly rose, and remained high, is to compare the distance of the bottom of the concrete jersey barrier to the inset video thumbnail of the left camera through the duration of the original 4 second video. The conclusion is clear. The video doesn't lie.
Putting your cursor on the small car in the background as the 4 second video plays is quite useful to debunk the idea that it could all be an illusion caused by the Cybertruck shifting to the left. That happens, but not until the point of impact.
Look at the termination point of the left lane line on the main image. Also look at its position relative to the text in the left camera thumbnail. It goes from the right of the 'f' to the left.
