loki
localhost
Received the Starlink Mini today. Posting a few photos I wish I saw before to get a better sense of how it might all come together.
The barrel connectors on the bottom of the dish and wall plug
Tesla Cybertruck Cybertruck + Starlink Mini -- Photos and Transfer Speed Numbers IMG_4F7065E77B61-1
The dish is very sensitive to the tilt and orientation of the device. The app will complain if it's not correct and will give you real time feedback as you move it
Tesla Cybertruck Cybertruck + Starlink Mini -- Photos and Transfer Speed Numbers IMG_0833
Putting it on the tonneau like I did will not work as it kept complaining about the tilt.
Tesla Cybertruck Cybertruck + Starlink Mini -- Photos and Transfer Speed Numbers IMG_2B191BB64650-1
I then tried placing it in the frunk, just because and got 64/4.8. Line of sight would have been partially blocked by the hood.
Tesla Cybertruck Cybertruck + Starlink Mini -- Photos and Transfer Speed Numbers IMG_0825
Placing it out in the open grass at the end I was able to get 108/3.1.
When the dish sank a bit as the speed test was running the speed dramatically dropped off.
rizvend
JAKEMBL
cybrtrk, aptera reserved
Nurse Informaticist
I'll give it a shot when I can but I'm not sure if it's going to be entirely reflective of true performance. There is a clear ceramic tint on the windshield which I'm not sure affects the speed.
...and there will also be a reflective white image while you drive upon reflection...?
LexusCyber
Marius
Redmond, WA, USA
Lexus LS460 AWD V8
do you need the starlink connection all the time? I think @Crissa came up with a sweet setup, albeit it required a bit of work and tinkering.
2 cheap /quick options I'd play with:
option 1: consider using a wood/plastic wedge to put under the antenna to change the tilt while on the tonneau
option 2 : make a dish support to attach it on one of the rails inside the truck bed. like some sort of arm extender in an S angled L shape. you install the dish on that and when you want to use the starlink you'd need to just open the tonneau
let us know what your final solution is.
loki
localhost
UP is selling option 2. I initially backordered for gen 2 but switched for the mini.
loki
localhost
Parked and misaligned by 33 degrees I still get a decent 85/9.9. I slightly misunderstood before and can still use it misaligned (on the tonneau or wherever) but just not have the optimal performance.
Tesla Cybertruck Cybertruck + Starlink Mini -- Photos and Transfer Speed Numbers IMG_0877
Tesla Cybertruck Cybertruck + Starlink Mini -- Photos and Transfer Speed Numbers IMG_0876
Not me, I live under the redwoods! Lotsa envy, tho.
I do sometimes mount the solar cells to the roof rack I have. That's kinda like that.
