- Oct 3, 2020
- Western Washington, USA
The duty cycle of the compressor I bought? I don't know that the manufacturer even rates it, if they do, I don't know what it is. And it doesn't matter in my application, because I will never run it past 5 minutes in any given hour.Its funny. Every link I post is not good enough for you. You always have a response. You didn't get the post. It's not runtime I am concerned with overall. It's *duty cycle*. Typically the cheaper the air compressor, the lower the duty cycle. As I stated before, the expensive ARBs (i.e. the twin air compressor) can have nearly 100% duty cycle times. Sure, I can buy that and be done with it. but for something I am going to use a handful of times, its a ridiculous amount to spend.
Again, Duty Cycle doesn't matter in this application unless you will be filling the tires on multiple vehicles, consecutively. Even then, the pause between hooking up to different vehicles would probably make duty cycle irrelevant on any compressor with enough volume capacity to be reasonable for the task at hand. Just buy a compressor that has enough volume capacity to fill them in one go.I linked to a Makita. I simply stated that I was *also* looking at a tank version mostly for duty cycle. All you had to say was, the one I have (still awaiting your link for what it is and where you got it) has a 100% duty cycle and can do all your tires in 1 shot. BOOM! Over. Perfect product for me. Thanks @HaulingAss... thats a great product and I will order one!
If I said addding a tank changes the duty cycle of a compressor, I mispoke. I meant the runtime would be longer, the duty cycle is a rating of the compressor itself, and doesn't change depending upon whether there is a tank involved. That said, there are different duty cycle ratings for different pressures (the duty cycle rating is shorter at higher tank pressures). And adding an inline tank is going to make the average working pressure higher and thus the duty cycle rating would be lower.Instead you go into some diatribe about how duty cycle is longer with a tank which is 100% untrue.
Because people like you, but with more money, will pay extra for that! Haha! Seriously, it sounds like something that might be needed if your 12V compressor is mounted in a hot engine bay, and is cycling on/off due to excessive heat. That will allow you to keep filling each tire even as the compressor shuts off. A marginal benefit in a different application than what we were discussing. something we don't have to worry about because our compressor won't be mounted in a hot engine bay. Duh. Do you really think it's going to overheat in 4 minutes?Ever wonder why ARB sells a 4L (1 gallon) tank as an add on to its twin air compressor?
Answer: no.
When I was a small child I told my mom I wanted a toothbrush with extra firm bristles. Sho told me that dentists recomended softer bristles. of course I thought she was full of it, otherwise why would the toothbrush companies even offer extra firm bristles? She taught me an important lesson when she said they will sell you anything you want, as long as you were willing to pay for it.
The smaller the tank size, the higher the duty cycle your compressor needs to be for a given continuous flow rate. Yes.I'll also let you Google the number of sites out there who have duty cycle calculator based on CFM and tank size. There are a lot. The main takeaway: Duty cycle is inversely proportional to tank size.
The reason that's not applicable here is because we are filling all four tires in one short but continuous runtime that is within the capability of the compressor. Duty cycle doesn't even enter into it as long as the compressor is sized so it can complete the fill in one run without overheating. The compressor will not shut off due to an overheat condition until the tires reach their target pressure, due to the high flow rate into all four tires simultaneously. The tires are like one large compressor air tank, you don't need two. You turn on the compressor, it fills up this large air tank up to 50 psi (or whatever yur target pressure is) and then you shut it off.
The MorrFlate style filling system leverages low pressures to fill all the tires faster. The compressor is never at a higher working pressure than what's in the tires at any given moment (ignoring the small pressure differential caused by friction in the hoses and valves). That's how it can fill them so fast without using a tank, the lower average working pressure reduces heat generation because compressors run more efficiently at lower pressures. When you use a tank you have to run the compressor at higher average pressures, because the tank cutoff pressure has to be considerably higher than the maximum tire pressure. That's because there is a pressure differential between the pressure at which the compressor turns on and the cut-off pressure. And the difference between the cut-off pressure and the differential pressure must be higher than your tire target pressure or the compressor will not bring your tire up to the desired pressure (without adjusting either the cutoff pressure higher or reducing the pressure differential). And there is a limit as to how small the pressure differential can be.
All of this works great when using pneumatic tools, but it's far from ideal for simply filling tires up in the field.
Yes. Because you can't seem to admit that you don't know what you are talking about, even to yourself.My ego? Seriously? Wow.
