firsttruck
Except for needing clearance for the sail panel, the Cybertruck should be just as capable of Fifth Wheel / Gooseneck towing as the ICE Ford F-150/RAM 1500/GMC-Chevy 1500.I agree but a bug should not be pulling anything really. Just because something can pull it does not mean it should. Certainly not a camper. It also has the engine in the rear so that would be a ton of weight on the rear axle I agree. I could pull a semi trailer with my truck. But braking and handling the load or handling cross winds is different. I just think the weight on the front axle would cause steering issues. When braking the weight would also shift towards the front even more. The CT could probably handle it. I just donāt think itās the optimal thing to do.
An auto-sliding 5th wheel hitch or even a auto-sliding king pin box on the trailer might help with cabin/bed clearance issues.
etrailer | Reese 5th Airborne 5th Wheel Air Ride King Pin with Sidewinder Review.
5th Airborne Sidewinder replaces your fifth-wheel trailer's king pin and alters the pivot point of your rig, enabling you to make up to 90-degree turns. Enclosed air spring in pin box absorbs shock and adjusts for a smooth ride.
The 5th-Wheel trailer's pivot point is moved an extra 22" toward the rear of your tow vehicle so that you can easily make 90-degree turns, even with a short-bed pickup truck
Dec 10, 2015
etrailer.com
etrailer | 5th Airborne Premium 5th Wheel Air Ride King Pin w/ Sidewinder and Turret - 16,000 lbs Item # RP61412
https://www.etrailer.com/Fifth-Wheel-King-Pin/Reese/RP61412.html
Do I Need a Sliding Fifth Wheel Hitch? This video helps clear the mud on fifth wheel hitches. You will learn the difference between a standard fifth wheel hitch and a sliding fifth wheel hitch, and what hitch is needed for your application.
Feb 25, 2020
How RVs Work
Pullrite SuperGlide, the best solution for short bed and super-short bed fifth wheel towing!
RAM trucks are so tall, the bed sides and trailer king pin, you need to mount hitch use lowest setting.
Demco Hijacker Autoslide 5th wheel: a quick look after 30 months
I really like this 5th wheel hitch. After using a manual slide and making a turn just a little too sharp, I put a nice dent right in the cab corner of our 2002 Dodge Cummins. Made me sick. After buying the 2017 RAM and going through the hassles of a manual slider, a super slider or auto slider was in order.
Dec 17, 2019
PM Tips
