cybertruck wont stay on high height
Sirkevin
when driving on dirt road, I change the height to high in drive under 25 but it keeps dropping back down to low anyone else having this issue or no workaround to keep the right height up when moving
jf64k
OP, are you in Off Road mode?
Sirkevin
foundation version i don't have a off road option
cybercoffee
MYLR
not having had the opportunity to go off-road yet with my cybertruck, I am left wondering--doesn't it always default back to low once you exceed 25 MPH, or does it really maintain a med or high suspension if you exceed 25 mph but you're in off-road mode?
tmeyer3
Trevor
www.meyerwine.com
Computer Scientist, Vintner
Rugged Baja mode remains in a high setting at higher speeds, but not a very high setting as that's too rigid. I like to number the suspension, ?:
0 - entry , rigid
1 - low, tight, best aero
2 - medium, soft, good flex
3 - high, tight, lots of of flex
4 - very high, rigid, low flex
5 - extract, extremely rigid, no flex
rudedawg78
Ernie
South Carolina
Freemarket
Southwest
Stay at home Daddy
On road, when you tap on High, you’ll need to then tap on “keep ride height until 25 mph” then it turns blue I believe. I was missing this myself and it would consistently go back to medium within 10-20 seconds as I recall.
Sirkevin
i was driving 10mph and it would return back to low. i have the latedt software release. prior to last update I recall having the option I believe in my profile to select the driving mode, but appear not to have an option anymore.
Tesla Cybertruck cybertruck wont stay on high height 1701587535219-png
Is this not what your "Dynamics" screen looks like?
mark555055c
Buffalo, NY
In on-road mode, you can not drive in the high suspension setting over 25mph or longer than 100ft.
This link has all you need to know.
https://www.tesla.com/ownersmanual/cybertruck/en_us/GUID-52FD0453-C200-4757-AC74-8D9BC4F00937.html
Sirkevin
thanks I was in comfort Drive mode not off-road mode but now I found that option and will use it next time as it appears in comfort mode you can't drive in hugh but low no matter what speed I'm going
Gaximus
Mead, CO
Software Developer
So I won’t be able to keep my suspension high when driving around town, above 25 mph?
