- Gus
- May 22, 2021
- Austin, TX
- 1981 DeLorean, 2024 Cybertruck
- IT Specialist
They were out of 4680s ?
Can you give us the details of your order ?Delivered! Colorado and CyberBeast.![]()
Range anxiety can be real in limited instances. I gave up on third-party charging networks over six years ago after failing to get any charge out of two of them. Yes, I have a short leash for stuff that doesn't work and has a better alternative.Thanks for the detailed info! As I've had 2 teslas prior to the CT (pickup Sunday) I would slightly disagree with the range anxiety. As I've planned to charge at 3rd party chargers to find out they were broken, and showed up with "0%" left at the next charger. Gave me some anxiety
I definitely gave up looking for them after almost getting stranded because of it.Range anxiety can be real in limited instances. I gave up on third-party charging networks over six years ago after failing to get any charge out of two of them. Yes, I have a short leash for stuff that doesn't work and has a better alternative.
So, I've suffered no range anxiety induced by broken third party chargers.
Of course there are still large sparsely populated areas where range anxiety is real, it's just that I, like most motorists from populous areas of the country, have no reason to go there. If we did, we wouldn't be prime candidates for EV adoption.
Were the gates accessing the upper trails still gated?Walker Valley ORV - Mount Vernon, WA
Yep, every single one.?Were the gates accessing the upper trails still gated?
You really shouldn't be going up there while the ground is so soft.Yep, every single one.?
The main road/trail didn’t feel too soft at all, not yesterday at least.You really shouldn't be going up there while the ground is so soft.
I know it sucks, but it's best if you want it to be there later.
The open one or the closed one?The main road/trail didn’t feel too soft at all, not yesterday at least.
Hence being open instead of closed?It’s the primary road going through that we stuck to. All of the side trail gates were closed.
sorry, a bit confused on that one. The gates for the “trails” were all closed, as in do not enter. What did you mean by “being open instead of closed”?Hence being open instead of closed?
