LuvOrH8
San Diego, CA
Cyber Truck
Good job for a budget job, but I really want one that integrates into the factory camera without the need to hook up a new rear camera. I'm sure someone will come out with some kit eventually that will be $500+. I'll be in line waiting...
TECH49
Philip
Keller, TX
MY, DM Cybertruck, C8-Z06
I've only test drove one, hoping to get mine next month (lol), but do you really get used to not having a good rear view mirror? I've used the digital one in a C8 Vette and it seemed better than the on screen one (just so tiny). Granted I am constantly using my rear mirror
I have a C8 and that digital mirror is fantastic. I had to read it twice when I learned the cybertruck doesn't have this. The most glaring omission in my book.
Cheap and cheerful solution.
WOLFBOX 12" 4K Rear View Mirror... https://www.amazon.com/dp/B0B1LLMCS9?ref=ppx_pop_mob_ap_share
I used the online service manual to work out how to remove the interior trim panels, the window seals and rear wheel arch liner. In summary, you don’t need any tools to do this at all. Everything just pulls off. Power is ran from the front USB-C outlet in the center console through a usb-c to 12v cigarette lighter adaptor
CERRXIAN 1ft USB C Male to 12V 8W... https://www.amazon.com/dp/B0BGL8ZRCS?ref=ppx_pop_mob_ap_share
I had to get an extension cable as it didn’t quite reach with the original cable.
NOCO GC019 15A 14AWG 12V Adapter,... https://www.amazon.com/dp/B00G8WLX14?ref=ppx_pop_mob_ap_share
Both cables (power and rear camera) run along the headlining then down the pillar trim. The power cable keeps going down to the floor then goes under the kickplate and under the front seat to the center console. The camera cable goes along the window tops by removing the window seal, then putting it back in on top of the cable. The cable then goes down the rear of the back door, under the rear fender and round inside the wheel arch trim. At the back of the rear fender I pulled the fender liner off and routed the cable through there to the tow bar, then put the fender liner back. The camera itself is stuck then zip tied to the tow bar bracket.
Small details
The usb-c does power off when the car shuts off (usually about 20 minutes after you leave it, assuming sentry mode is off)
There is a wire on the camera loom that you are supposed to connect to the reversing lights to trigger the rear camera. You don’t need to connect this to anything. Instead you can just select the rear view on the mirror and it stays like that (even through power cycles)
As the cybertruck mirror is really small, I needed to use a piece of foam between it and the digital mirror, otherwise the straps that are used to attach the digital mirror are too loose and the mirror rattles around.
This mirror has a gps attachment, used to give positional info to the dash cam it has built in. I didn’t connect this because I’m not interested in the dashcam feature for this application.
PROs
It works.
It’s a 4k camera. Image is clear and field of view feels right.
Cheap (less than $250 all in).
Only took a few hours to fit.
Completely reversible if needed (I didn’t drill or cut anything, or tap into any wiring).
You still have a rear view mirror even when the tailgate is down (unlike the native camera).
No wiring visible on the outside of the truck and I didnt need to work out how to route a wire from the cab into the bed.
GOTCHAS
You can see wires inside the cabin at the top of the mirror for a few inches until they tuck into the headliner. I tried but failed to route the wires underneath the roof console (the thing with the hazzard button and drive selectors). I took it off but it is really packed inside there and I couldn't get the wires ran and get the roof console to clip back in.
You need to run with your tow bar cover off (We do anyway because we do tow with the truck)
It won’t work if you are towing, meaning you get an excellent view of the front of your trailer and nothing else (when towing we used the full camera view on the main touchscreen and that was fine)
I’m not sure how the camera will fare down there with regards to getting dirty. Maybe it’ll be ok because it’s kind of sheltered, maybe not. Time will tell.
The mirror shape is kind of rounded. A Cybertruck no-no ? Maybe someone will make a nice angular Cybertruck version at some point!
One reason why I want the upper light bar is that I wanted to get one of these that has side cameras and a rear camera and to mount them facing backward on the upper lightbar (side cameras read and down of course). Then the question is, can we use the power cable for the interior-facing camera in the upper console and just remove/replace the Tesla mirror altogether. Had you thought of any of these?
Reactions: Mal
My problem with the factory camera is that it gets dirty too easily. That is why I want to mount the rear-facing camera up high, where the upper light bar would be if I could get one.
Reactions: Mal
TwiztOG43
Las Vegas
Tesla Model Y Performance, Tesla Model Y LR
Is there a version that includes an additional camera? Would be nice to add one for inside the bed too (similar to the Rivian)
96Kopper02
Iowa
Tesla Model S
Physician
I’m still trying to figure out what the difference is between having the rear view camera display in the center screen versus in the rear view mirror? I don’t have my truck yet but assume one would just need to retrain his/her brain to look at the screen instead of up at the mirror…I suspect removing the mirror altogether would reinforce this.
TexasRaider
JR
Denton
Cybertruck + MS
Civil
Small details
PROs
It works.
GOTCHAS
I’ve had a Wolfbox for years on my Toyota. A solid rear view camera mirror touchscreen. Not the best quality, but definitely good enough for $120 or so off Amazon.
jf64k
Why didn't tesla do this from the get go. These have been around a while and quite a few OEM manufactures have used them. Guess they were two busy working with Goodyear on tires and aero covers. It would be GREAT if we could figure out how to tap the rear camera feed.
Needless to say Great Work!
Yes!!
I had one on my 2017 Chevy Bolt. The lever underneath that would normally toggle a regular mirror between day/night would instead toggle the mirror between regular mirror and the digital rear view. It worked great!!.
cgladue
Chad
Massachusetts
Software Architect
Yes. You get used to using your side mirrors mainly. They are totally sufficient sometimes I use the rear view also. But mainly the side mirros and the left and right repeater camera feed when the turn signal is on.
Don't miss the rear view mirror at all. At 4300 miles so far and don't miss it
cyberhornet
cyberhornet
2019 M3
Software
Small details
PROs
It works.
GOTCHAS
Very Smart!!
SARC
Scott
Morgan Hill, CA
AWD CT FS, 2023 Model S Long Range
Agreed. That’s why I made sure my cheap solution is reversible. I would likely pay more for a better overall solution also
I think if I only drove the CT, I would also get used to it. My situation is I drive multiple vehicles, and they all have rear view mirrors, except the CT, and my muscle memory isn’t smart enough to be car specific ?
rizvend
JAKEMBL
cybrtrk, aptera reserved
Nurse Informaticist
Small details
PROs
It works.
GOTCHAS
Is there room to add an additional camera for trailer pulling? ???
TheDarkRanger
Kevin
Tropic, UT
1966 Ford 4400 Industrial Tractor, 1995 7.0L Ford Dump Truck, 2000 Dodge Dakota 4wd QuadCab, 2000 F350 4wd, Tesla Model 3
Park Ranger / Astronomy Entertainer
Thanks!
I got mine! There might still be 3 left? ?
Also a nice find with the cigarette lighter style 12 DC jack (google it kiddos!). I was wondering how I was going to power my top-$ radar detector.
112mph is kinda pokey compared to my M3. But still expensive... if I don't know who is watching and from which direction.
cgladue
Chad
Massachusetts
Software Architect
driving CT and any other vehicle has already made me almost hit one of my other cars because i didnt turn the damn wheel enough, lol after driving steer by wire it feels like stone age!!
cgladue
Chad
Massachusetts
Software Architect
Thanks!
or you just drive at a responsible speed like other drivers ?
