pae1andonly
- Paul
- Apr 29, 2025
- 2024 RAM 2500
- Retired
Possibly an alternate manifestation of the leaky rear window issue. Easy for a rear-seater to check, but if you usually run solo you can put a hand up over your head and check the rear drivers side window seal.
There is a procedure in the manual to re-calibrate windows. Which works ... for a while.
If discovered while driving, slightly lowering the rear window can make air flow - and noise - largely go away.
