I don't think so. Trolling motors for bass boats run off 12v batteries. It won't need much power and we know the bed already has electrical plugs. There is no reason for a PTO.
The PTO is most definitely just a cable connection, not a mechanical output, as this would require a dedicated gearbox, clutch etc to operate. I think a 12V trolling motor won't do enough at all, better off having a turbine wheel design and deflector ducts on the inside of the wheel to produce thrust.
I donā€™t see a PTO happening, but someone might well want to move faster than a trolling motor can pull off.
Papillion, NE
Operations Planner
For sure. I don't see anyone seriously wanting the CT for regular water crossings. Maybe once at the lake to try it off/show it off... LOL... But, if someone were in a position where they lived on an island close enough and didn't want to have to switch to a boat all the time (grocery runs, bad weather, etc), I could see a remote deployable, phone controlled (or CT controlled) trolling motor set up where the rotor could be dropped down a bit from the receiver hitch. Even if it was fixed, you can get moving quite a bit using one. Well, in a bass boat, I can... The CT probably won't slip through the water quite as well. Now, I'm wondering if Tesla will make a plug and play downscanning sonar that displays on the main screen...
If you're hitting the water frequently, you'd want to stick something into the truck that didn't stick out too far, so like a jet propulsion system of some sort. Probably could fit that into the chassis behind the battery.
Maybe they can pulse the external speaker and use the built in mics to do some range finding with a OTA update? šŸ˜Ž
firsttruck
mx
Water depth detection could enhance safety for stream fording off-roaders or even regular drivers that find themselves and family in flooded roadway situation.
Off-roaders who frequently ford supposedly shallow streams might have use for detecting water deep. Even regular on-road users that were in flooding situations could use water depth info. In both cases the driver might be intending to only drive through water with wheels remaining on the bottom/road but instead encounter deeper water ( NOT using boat mode flotation ). An inexpensive water depth detector mounted on front of vehicle could enhance safety by warning of deep sinkholes in stream, washed out sections in paved road in what appears as normal depth flooded area or other obstacles underwater that might prevent driving further.
Handheld depth finders are extremely affordable and come with a lower price tag than fish finders. Some are priced at less than $100.
Fish Finder vs Depth Finder: Which Option is Better?
By Coty Perry Last Updated on June 15, 2022
https://yourbassguy.com/fish-finders/fish-finder-vs-depth-finder/
Determine Accurate Water Depth for Your Worksite with a Sonar Fish Finder
| Aqua-Barrier | Cofferdam | Construction | Dewatering |
Aqua-Barrier
Jan 18, 2017
https://aquabarrier.com/blog/uncate...h-for-your-worksite-with-a-sonar-fish-finder/
If it's a water jet with electric motor then you could probably fit it in or under the rear bumper. A jet ski one is only around 4-5" in diameter. It will need a steerable nozzle with reverse scoop. I'd expect around 5-10knots with about 20-30kW but it won't get on a plane unless you do this:
Tesla Cybertruck Elon says Cybertruck might have options for hitch mounted motor propeller or special wheel hub with paddles šŸš£ā€ā™‚ļø images (38)
Papillion, NE
Operations Planner
Props are more efficient. That's probably probably why boats that hit the water frequently use them. I picture a more compact motor/propeller that is up out of the slipstream of air when driving but can be lowered remotely to just below the receiver hitch for aquatic adventures.
Water jets are over 60ŁŖ eff, the intake is flush, and the outlet should be just above the waterline. It also can't hit the bottom, and is much safer around people, and can be used without issue in shallow water or to help push you up the beach.
Iā€™d normally agree, but Isnā€™t this whole thread tilting at that particular windmill?
If you just wanted it for the occasional Creek fording or emergencies, you could just use the inefficient wheel spinning to get across.
People are talking about permanent mounts. You donā€™t need any of this to strap a trolling motor to the tailgate
Papillion, NE
Operations Planner
People are talking about permanent mounts. You donā€™t need any of this to strao a trolling motor to the tailgate
I agree. The utility is probably more with flooded streets than fishing.
Anyone want to do a meet up at lake Erie to invade Canada by water?
I would not want to drive a ā€œSometimes Boatā€ on a big body of water like that. The waves get a lot bigger on the big lakes. Youā€™d likely have swells washing over the windshield with moderate winds. I guess that would put the BAW to work.
FutureBoy
Reginald
Kirkland WA USA
Toyota Sienna
Financial Advisor
BAW is used as an oar to propel the CT through water. CT being a boat has been right in front of us this whole time!!
