Cybertruck 1974
Cybertruck 1974
Everywhere
not bad, too wide of a swing, needs a stop earlier
Why? Wouldn't anyone want to have it swing all the out to have room to load? I've never seen any swing arm stop early.
elyliu
Los Angeles, CA
CyberTruck AWD, Model X 90D, Model 3 AWD
Can you provide a picture of the rear camera feed from the center screen?
My F-150 has a spare under the bed, forward of the tailgate. It's been down there 14 years and I've never used it. When the truck was new, I used to keep it aired up. But then I realized I'll never use it and stopped maintaining it. 14 years later I've never used it. Never needed the tire plugs I carry either. But I would much rather have plugs that I'll never use than an entire tire/wheel assembly. When I buy new tires, I only buy 4 and never think of replacing the spare too.
I've been trying to replace my aged spare on my Mazda - we've never used it and it's over ten years old - and haven't been able to find the replacement anywhere.
CarMan ElecTruck
Other Earth
LeftFoot RightFoot
Looks like a windup toy now… kinda cool. ?
Or the Penny Racers which popped wheelies…
Cybertruck 1974
Cybertruck 1974
Everywhere
my '94 Bronco swings off to the side with a stop, i'd say at a 45 degree angle, doesn't swing away hard and fast and boom against the stop, and makes it easier to grab to swing back into position after you close the tailgate and off you go. also reduces possible damage to the side of the truck with a larger tire mounted and not only that, reduces possibility of the tire swinging into your neighbor parked next to you at home depot when you're loading that lumber.
Huh? I've never had that problem. All of my swing arms on my Hummer, Jeep and now Cybertruck have resistance when opening. Are you throwing the thing open as hard as you can? ? Maybe lift a few weights daily and in a month you'll be fine.
SmittyVegas
North Dakota
2019 Toyota Avalon Hybrid Limited
H/A Consultant
Blocks view of rear license plate so probably not legal?
Silva111
Joe
Valley Center CA
No Tesla
I'll buy one with a propane grill attachment or an electric flat iro, or a TV mount? I can test it! ?
countryboy
East TN
M3P | CT FS AWD
That's legit badass! But if they're calling this a true Cybertruck integrated solution it should have a way to relocate the camera.
BannedByTMC
NYS
A solution for camera and plate would be a carrier with an offset mounting to one side. No real reason to have it centered.
sylvius
SE PA
CyberBeast FS ordered
On a 35” tire I think even offset it will cross the midline of the truck and block the camera.
as for the license plate, I’m pretty sure in PA it’s legal to block the plate with a rear cargo carrier that’s in use but not when not in use. So a bike rack with bikes in it is ok but an empty rack folded up and blocking the plates they could technically pull you over. I’m sure other states have different rules about it.
Dirt Worker
Todd
McMinnville, OR
Corvair Corsa, Mini Cooper, T880 Kenworth, CT
Excavation Company
Does it come with an idiot proof tailgate disabler? It's gonna happen. Nice idea but too many downsides. Wind drag, cost, inconvenience, camera blocked, shimmy, increased length and it doesn't seem like a tight fit. Hope to see more of your thoughts after practical experience.
Wow, good for you. As for me. I off road and drive 30k miles a year and go through a tire a year. Plugs would never work in any of my flats. So again, good. For. You.
Have you ever even used tire plugs? It doesn't sound like it.
