Does anyone know that the vertical and horizontal compression and tension loads are on the front of the Cybertruck?
It won’t be good for the CT if the snowplow setup exceeds that during use.
At those points? Pretty much zero. Tow hooks only expect to see pulling/ tension loads, not compression (other than crash), not vertical, and definitely not long lever arm torques.
(Unless Tesla preplanned for accessories)
Gyzz
Kristian
Houston, TX
(TMS 15', TMY 21') CB
I LOVE it
Come rain come snow
Let that truck work ???
getsometom
Tom
I'm not familiar with snow plow attachments. The pictures make it seem like the plow is attached to a hitch, which is attached to a bracket that is attached to the front tow hooks. Is this the normal way of attaching a snow plow or is it jerry-rigged? My assumption is more attachment points can lead to more potential issues outside of the horizontal compression forces other have mentioned.
Cybertruck Dude
Illinois
OperatingEngineer
Saw this custom snowplow install on a Cybertruck online. No other info yet.
It would be cool to see a stainless steel V snowplow engineered properly through Tesla. I’m sure they can engineer and streamline a V plow.?
Killlbox
Stacy
Cheyenne, Wy
I do what I want
I'd love a smaller and lighter version to clear the driveway. Hopefully a more refined versions comes out before winter hits.
gillfoto
Kenneth
Juneau, Alaska
www.flickr.com
'23 Model Y LR, Cybertruck FS 2024
Ok, I know how people can be, so please refrain from any highly strung emotional outburst as it might endanger your health.
Sitting comfortably, so for over ten years I've been successfully plowing my driveway with a relatively inexpensive light weight plow by DR. Power; it's made with aluminum and rubber.
All I need on the Cybertruck is a front end hitch receiver which enable to continue this practice.
I keep the ATV for "tidy up" and getting into tighter places
Tesla Cybertruck First Snowplow installed on a Cybertruck Screenshot Receiver 1
Tesla Cybertruck First Snowplow installed on a Cybertruck Front Hitch Bracket 2
Tesla Cybertruck First Snowplow installed on a Cybertruck Plow 3
Tesla Cybertruck First Snowplow installed on a Cybertruck Tundra 1
Tesla Cybertruck First Snowplow installed on a Cybertruck Tundra 2
Tesla Cybertruck First Snowplow installed on a Cybertruck Tidy Up ATV
Next WhistlinDiesel video...
A ladder frame truck with a front mounted engine has slightly different design margins and mount points than a cast EV...
BannedByTMC
NYS
Presumably a truck expected to travel off road would have tow hooks built for vertical as well as side loading. If you get stuck you can't always count on being pulled straight ahead. That said, repeated plow use seems like a good way to introduce stress cracks into the casting unless you go very easy.
