Front license plate blocks the front camera. Will autopilot / FSD be affected?
wheeler
San Jose, CA
2024 MYLR, 2024 CTAWD
I installed a very slim license plate frame on the front plate holder that comes with CT. And found that it is blocking the front camera in the left lower corner.
Tesla Cybertruck Front license plate blocks the front camera. Will autopilot / FSD be affected? 61yN4Vsv6FL._AC_SL1500_
Tesla Cybertruck Front license plate blocks the front camera. Will autopilot / FSD be affected? 20240508140052
Tesla Cybertruck Front license plate blocks the front camera. Will autopilot / FSD be affected? 20240508140033
The license plate itself is also blocking a little bit without the frame. I didn't notice that before the frame installed. The photo below is without the frame, showing a dark triangle area behind the wash camera button.
Tesla Cybertruck Front license plate blocks the front camera. Will autopilot / FSD be affected? 20240508140105
I'm wondering how this will affect auto pilot :unsure:.
Now I'm looking for an after market front license plate holder to avoid this.
Update:
Tested CyberBandit front license plate mount. A plate mounted in the middle without a frame also block the camera.
Tesla Cybertruck Front license plate blocks the front camera. Will autopilot / FSD be affected? 20240510142354
Tesla Cybertruck Front license plate blocks the front camera. Will autopilot / FSD be affected? 20240510142403
But it can be easily mounted off-center all over the front bumper. So this will be my solution for now.
Update:
Just heard that SnapPlate is not blocking the front camera.
wheeler
San Jose, CA
This photo seems to be nonsensically edited. I have no idea what you're showing.
It is a close up showing the dark triangle area behind the wash camera button.
...This looks terrible, but why hasn't anyone else noticed it before now? Is your camera mounted differently? Is it inset a little bit, maybe?
I have no idea. I never touched the camera.
RollingRefrigerator
Eric
San Jose, CA
Foundation AWD CT, M3P, MYP
Simple fix - remove the whole damn thing. Yes, I know, CA law requires a front plate, but I've been driving 4 different cars over the last 20 years in CA without a front plate, and have never been pulled over for it. I've been pulled over for other things multiple times, and still didn't get any flack about not having a front plate or my illegal tint. But yes these were all "nice" cars so I am surely betting the benefit of any profiling the cops are doing. YMMV!
In my opinion they totally throw off the look of a car, and might slightly affect aerodynamic efficiency as well, so I say no to front plates.
getsometom
Tom
A few things you can check.
1. Verify your front camera is positioned correctly with Tesla.
2. Check the dimensions of your license plate frame? Plates in the US are 12"x6", plate frames are naturally a tad bigger than license plates to cover the edges. Some frames are bigger than others. The ones I use are 12.3" x 6.5"
3. Verify the plate bracket backing is positioned correctly during install and there is no slack or space between the bracket backing and the front bumper. The closer you can get the entire thing mounted to the bumper, the better it will be for your camera's visibility.
What does the camera image look like without a plate frame? If your camera sees the plate without a frame, Tesla needs to adjust the camera to allow full visibility as any frame will further hinder visibility.
gaubong053
Tuan
Sacramento, CA
MXP, Cybertruck AWD FS.
Software engineer
I am seeing the same thing. As the front camera has very wide angle so very small block would not affect FSD if it ever uses the camera.
Tesla Cybertruck Front license plate blocks the front camera. Will autopilot / FSD be affected? IMG_5640
Fedork
Fedor
Software engineer
I put on the front licence plate without any frame and I noticed the camera blockage as well. I assume this is just an oversight on Tesla part. Hopefully does not affect autopilot, but is somewhat annoying. Maybe they can fix it by providing a different mount? Not sure if that is possible, maybe thinner one would work?
WRT the comments about not mounting front plates at all - I considered it, but I have yellow-on-black custom plates and they look really nice on CT, so no loss there
wheeler
San Jose, CA
Update:
Updated.
wheeler
San Jose, CA
Just learnt that SnapPlate is not blocking the front camera.?
The Tesla Guy
Daniel
Washington
youtubeteslaguy.com
The issue is that the bottom of the plate juts out when the 2 lower screws are not installed as is the case with a frame where the plate drops into the equivalent of a slot via two tabs.. (see photo) Merely applying slight pressure to the bottom of the frame eliminates the camera blockage.
installing just a license plate per Tesla’s instructions without a frame does in fact eliminate the camera blocking.
(see Tesla instructions)
A low profile frame with 4 screw holes might work, if such a thing exists
Tesla Cybertruck Front license plate blocks the front camera. Will autopilot / FSD be affected? IMG_2094
Tesla Cybertruck Front license plate blocks the front camera. Will autopilot / FSD be affected? IMG_2092
Tesla Cybertruck Front license plate blocks the front camera. Will autopilot / FSD be affected? IMG_2093
