AZCYBER
Ron
Tucson, Az
2020 Tesla Model S
Take that, Cinderella!
So you thought you were off to the ICE BALL !?!?
SS kitchen appliances are easy to clean. The CT will be easy to clean. You just have to do it. WTF is the big deal? Spray Way Glass Cleaner from Costco works great.
WHIZZARD OF OZ
Ivan
VW Up!
Electric Wheelchair Builder
Surface prep/repair.......3 easy steps, beginning with
Step 1: 'SCOTCH-BRITE'
Step 2: RENU Waterless Wash 'AR CYBER'
Step 3: RENU surface finish CYBER SHIELD
At least that's how they probably prep in Tesla showrooms and delivery centre!
But yes....'Glass Cleaner' & cloth in the CT drawer/glove box...good to go!
mhaze
mhike
Correct. This is a question that should be answered by Tesla.
davelloydbrown
Dave
model 3, silverado
veterinarian - retired
In every tesla (CT included) there is an electric door switch on top of the arm rest, but there is also a mechanical door latch below that in the hole in the arm rest in cases of emergency.
Every tesla owner should be aware of that. Alot of people who have been in my tesla for the first time will end up using the mechanical door latch my mistake.
jerhenderson
Jeremy
Prince George BC
Correctional Officer
lol you have the latch in a fire. if you're underwater, you're probably dead already.
ldjessee
Lloyd
Indiana, USA
Everyone knows why a break / break point tool works, right?
Also now that you can design material to be stronger in one direction than another?
Like I would want the window tougher from the outside than the inside, and laminate allows you to do that…
As for floating, the Wade mode pressurizes the battery pack (and probably electronics compartments) to help fight water intrusion… which could mean a larger buoyancy than one might think…
And as for displacement, larger than a R1T, but weights less… to mean, that gives it a better chance.
It is weight vs displacement, not just weight…
Otherwise battleships, aircraft carriers, cruise ships, and container ships would all sink.
I am. Or sure if the Cybertruck ‘Floats’ but it cannot be worse than a wrangler…
ldjessee
Lloyd
Indiana, USA
They referred to it as the SCUBA pack in the most recent video…
DJAlan2000
Alan
Oxnard, CA
Just use the explosive bolts to blow the doors off! They can be activated by pulling down on BOTH stalks at the same time and then pressing both buttons on the ends of the stalks... Of course this does NOT work on the SEXY models... :D
