CybertruckWraps
Columbia, SC
Cybertruck FS AWD
Best place I have seen yet for it! Awesome!
Carrying a spare when taking challenging off-road trips is important in case of a major tire failure and having to call for recovery assuming a recovery service is available. My solution for carrying a spare has evolved over the past year from carrying it in the vault to strapping it to a rack on the truck.
Both methods had disadvantages. The spare tire is heavy and huge. It takes up a lot of space in the vault. Strapping it to the top of the truck negatively impacts aerodynamics and driving range, and is vulnerable to being stolen.
When I chose to install the @Urander bed rack and Inspired Overland Carbonlite tent, how to carry the spare again presented itself.
The Urander rack expands the cargo carrying capacity of the Cybertruck along with improving the look of the vehicle (I've received more positive remarks about the look of the truck since I installed the rack).
After watching YouTube videos from Bearded Tesla Guy and Teslatino, adding the compact Carbonlite tent became an obvious enhancement for my overland vehicle.
Carrying the spare on top of the truck became impractical, and going back to putting it in the vault was a non-starter. My solution was to mount it inside the Urander rack leaving the vault available for carrying camping gear.
The tire is raised up tight to the underside of the rack using a Lippert winch mounted to two Urander crossbars.
I put the spare face down in the bed (or on top of the closed tonneau), and attach the hoist cable to the inside surface of the wheel.
I used a couple of leftover mounting brackets that came with the Carbonlite tent to capture the cable end piece instead of the usual practice of inserting it through the center hole in the wheel.
I use a Makita driver and 3/4" 6-point socket to raise and lower the tire either from the bed or from the closed tonneau. It's effortless (except for lifting the spare into and out of the bed).
Here's what it looks like with the tonneau closed.
Urander advised me to support the winch on two crossbars for a 100 lb tire. The winch capacity is 150 lbs.
I'm very pleased with how this worked out. Once I get the spare into the bed (with help if I can get it), raising and lowering the spare is super easy. There's no noticeable loss of range by carrying the spare this way.
Note: Putting the hoist cable end piece through the 2" diameter hole of the center of the wheel didn't work well. The tire was impossible to keep balanced horizontally, making the raising and lowering of the tire an awkward chore.
With the spare in place, loading and unloading the bed is somewhat more difficult, but not overly so.
sys700
Rod
Portage, MI
Foundation Series Cyberbeast (August 2024 - 26###)
Yeah, there's no question about it. It's a compromise that I was willing to make. On the highway I like to stop every 150 - 160 miles anyway, so adding a little extra charge makes up for the loss of range. Once off road, the range loss due to the rack and tent is minimal due to slower speeds. I also removed my side mirrors to help lessen the efficiency loss.
What is this?
Tesla Cybertruck How I Carry a Spare When Off-road Adventuring -- Mounted to Underside of Bed Rack 1739718874786-qi
Cybergirl
Cybergirl
Illinois and Arizona
For someone going off the pavement often it is a no brainier, tough for me as I use it for a work vehicle, commute vehicle, and sometimes an off-road vehicle so the range hit is a real concern. Your setup is nice enough that I might take the range hit though, very nice work.
Thank you!
Cybergirl
Cybergirl
Thank you so much! I don’t see numbers like that ever (but I have a lead foot and a CB).
Did you have any whistling or wind noise problems with your tent like they did with the Mars install (I don’t know if you saw that video)?
Really seems like an epic set up! How happy with it are you (1-10)?
There's always room for improvement so I'd say 9.
SentinelOne
See Sig
fantastic setup! I cant do it because commute/hauling dirtbikes/own an RV, etc but would love to have a CT Camping Setup with Rack/Solar, etc....hmmm,maybe I need a second Cyber Truck! :cool: (not really, maybe)
FarAway
I.
Central Virginia
Very clever!
kudos.
Friday
Grover's Mill, NJ
I'm at the point of ordering the spare. I need to use up my $2500 credit so I'm thinking of buying 2 cargo dividers. One would be used to hold the spare upright against the front of the vault behind the back window. Of course there will be additional strapping to the side L-track to hold it fast, like a strap netting or some kind of backup mount.
Has anyone seen examples of an upright install like I'm thinking?
I'm getting the molle panels also.
Example of what I'm thinking exampled by a standard pickup pic attached.
Tesla Cybertruck How I Carry a Spare When Off-road Adventuring -- Mounted to Underside of Bed Rack Screenshot 2025-02-21 at 06.41.11
Cybergirl
Cybergirl
The disadvantage of this approach is not being able to close the tonneau cover.
Friday
Grover's Mill, NJ
Yes, I didn't measure before I posted and it should have been obvious I guess flat is the only way to stow the spare for tonneau to close.
I blame flu-brain. Seriously, avoid this crud if you can.
