Loudness
Jay
Atlanta
Cybertruck (AWD)
I recently took advantage of the $299 deal for the Starlink Mini, and decided to mount it to the inside of the Cybertruck’s panoramic roof glass. It's super clean, no wire visible (except a short bit between the dish and the trim) and fits beautifully under the OEM sunshade.
After a little research, I chose a suction cup mount from ContronX, which promised a secure hold without damaging the glass. The challenge was to route the power cable cleanly to the Cybertruck’s power outlet. Here’s how I made it happen.
I chose to mount it just behind the front seats, leaving enough room to slide it out of the mount if I want to use it without the CT. The ContronX mount makes it easy to remove the Mini without unlatching the suction cups. It would have been a little bit cleaner on the wiring if I lined it up next to the rear trim, but I didn't want to shrink the headroom for a middle seat occupant.
Tesla Cybertruck Installed Starlink Mini under roof glass starlink_mini1
Running the power cable was the trickiest part, as I wanted a clean, factory-like look. Starting at the Starlink Mini, I tucked the cable under the interior trim along the back edge of the roof glass. The Cybertruck’s trim is flexible enough to gently pry up with a plastic trim tool, allowing me to hide the cable without damaging anything.
From there, I tucked the cable down along the rear seat edge, using a spudger to tuck it deep and hide it completely. To keep things seamless, I ran the cable across to the the center under the rear seats and then under the floor mat. Finally, I brought the cable up to the Cybertruck’s power outlet near the center console. You can see the white brick under there. I have an option to convert it to USB-C and use one of those plugs, but I already have another accessory there, and I'm not using the 120v for anything else at the moment. The entire process took about 15 minutes.
Tesla Cybertruck Installed Starlink Mini under roof glass starlink_mini2
With the sunshade installed, you can't really see it unless you're looking for it, especially at night.
Tesla Cybertruck Installed Starlink Mini under roof glass starlink_mini3
The connectivity is great, I'm hitting about ~150Mbps up and ~14Mbps down with a 20ms ping while driving around. For me, something like this isn't really needed 90% of the time, since 5G on my phone is faster and the Foundation CT has lifetime premium connectivity over 4G (which works great), but it's nice to have for those times when I'm out in the boonies. Plus, it's fun being a 3.5 ton rolling hotspot ?
brur
bruce
prescott az
tesla plaid
Maybe it's my latitude, or maybe my skylight has more tint from the factory, but I can't get any connection through the glass. However, it is my experience that it is impossible to establish a connection with your installation style from my location.
In my case I have to place the dish outside the CT.
wish it was possible for me, as what you did was what I wanted.
dw321
Ram 2500, Toytota 4 Runner, Bikonit Ebike
That seems weird. I just put my mini on the dash on a towell and great signal.
Loudness
Loudness
Jay
Atlanta
Cybertruck (AWD)
That's unfortunate, yeah. It's possible they changed the glass at some point. I got my AWD a little over a year ago, it's in the 10,500 VIN range, and it has no problem with passing the signal through.
Same, I had it there until the mount arrived. No issues at all with connectivity.
conorearly
Conor
Kalamazoo, MI
Nurse Anesthetist
@Loudness Thank you for the kind words and the great write-up! We’re thrilled to hear the ConTronX Starlink mount is working well for you. Happy travels, and let us know if you ever need anything!
Second Comment (External Mount Details):
@brur – We also offer an external mount option, which we use on our own Cybertruck! It uses strong 120lb magnets to sandwich the glass, securing the mount while keeping the installation clean and non-invasive. The power cable is routed discreetly between the trim pieces to the rear bed outlet. The magnets provide a rock-solid grip while still allowing for quick and easy removal when needed.
Check out our setup here: https://www.cybertruckownersclub.co...how-do-you-keep-them-safe.39286/post-30552489
or at https://contronx.com/
Let us know if you have any questions—we’re happy to help!
TexasRaider
JR
Denton
Cybertruck + MS
Civil
Thanks for details and information.
How long have you used this setup?
area51
Neurosurgeon
Hate to be a downer. As a neurosurgeon I don’t recommend keeping any loose or easily detachable devices on the dash or mounted on the glass. In a bad accident these become projectiles that can cause serious skull, face and brain injuries.
araxara
Alex
Tucson, AZ
CT, Model X, Lucid Air (DE-R)
Tesla Cybertruck Installed Starlink Mini under roof glass IMG_2965
Works great in this position and cable gets tucked in and routed with no visibility. I’m in AZ and reception is decent. Anywhere from 20Mbps to 120Mbps while traveling in the mountains where there is no cell reception. I use it primarily to listen to XM and keep my phone connected.
DEAKBS
Solvang
2025 AWD Cybertruck
Radiologic/CT Technologist
Question for anyone who already owns the Starlink Mini: if I purchase the Starlink Mini, do I have to start paying for the subscription service right away as well?
jonesw67
Warren
AR
FS Cyberbeast
When you activate it you will be charged the first month of $50 but you can then pause the service for following months until you need it.
CyberVeteran
2024 Tesla Cybertruck
Health Care
No you do not, and it is nice because you can pause the subscription at any time. I installed mine about a week ago.
DEAKBS
Solvang
2025 AWD Cybertruck
So as long as I dont activate it, the $50 subscription fee will not go through?
jonesw67
Warren
AR
FS Cyberbeast
Appreciate the write up
This is almost the exact same as I have just done. Slightly different mount as I dont plan on putting it in and out. and I went with the USB-C connection so I can control the "accessories" option in the outlet/power menu
My son loves being able to take his ipad in the car now and have access to his apps without us having to keep putting our phone hotspot on.
