mstatkus
- Mark
- Jun 28, 2024
- WA
- Cybertruck, Model Y, Model 3
- DevOps
MyQ has been ok but couple warnings (2 cars use it)-
1. Washing the car can often lead to that “closing in x feet” and you need to watch that. Sends the message to close the garage door as you’re driving in - at least a slight risk.
2. I periodically have to keep re-linking myQ and it’s irritating. Not sure what the cause is.
3. Network Error has Occurred - some issue with cell/wifi I think but as I’ve left I’ve had it not send the command.
Debugging - I’ve seen it where I put it in park, then back in drive the network reset and then I can issue the close manually.
I’d say it’s 80% awesome, 20% irritating. Just have to watch it and deal with these tech hurdles.
Also a case where sometimes it just closes and other times it does this beeping / blinking light then closes. Not sure why the difference.
Also - I have 4 Doors. This was a carport conversion to a garage. I actively use 2 rear doors for the cars. You simply set the door “set garage location” then desired distance to close/open and chime if you want to hear it. UI does show “Opening in x feet” or “closing in x feet”.
UI gives you a QR Code to re-sync your car via your myQ phone app. But like I said I’ve had some mixed behaviors with it sticking.
myQ made a hub which is what I had that supported 4. I found later you could buy the newer white one that only seemed to support 2. So in order to get more sensors for my other doors I got the white hub w/ sensor for $19 at home depot. Sensors by themselves were like $29 lol.
