Losing 10% charge a day (Sentry Mode on)
Darth abbott
Mn
Thanks. That’s when it most needed, no?
Yeah I mean it is kind of a bummer that it does pull that much power. So you kind of got to watch it if you're going to leave it for a long period of time like my trip I knew it was going to be sitting there for two and a half days at the airport and planned on it losing 10% of a. So I knew I'd be good leaving it on. You can always shut it off if it's getting too low plus it will shut off at 20% anyways. Yeah I would be really nice though if it used like five or less percent a day.
Darth abbott
Mn
I lose 3% from 10pm-7am if I leave sentry on.. so I imagine all day would be 7-10%
It definitely depends on the circumstances how much percentage it loses. I think planning on 10 is good but I averaged a little less so 8 and 9 I think per day. I had 16 Century events in that 59 hour.
jimnycricket65
jimnycricket65
Maybe, just maybe this will be corrected with updates in the future.
does anyone know if the x s or 3 drain as much?
jimnycricket65
jimnycricket65
My 2024 Model X will lose 10% charge per day if left with Sentry ON. Approx 1% per day of OFF.
Thanks for taking time to respond. I have a good sense on sentry mode vs battery usage across the board. AND, Tesla has not and cannot improve on this, yet.
DerekCyber80s
Derek
Roseville
Teacher
Sentry does drain a few percent. Obviously while out an about it’s worth it. Change the settings to be off at home. Maybe hook a ring cam up where you park. Also with the heat depending where you are has meant that cabin cool kicks on more than normal. I changed my setting to 100 degrees. These changes have led to only a couple percent drain.
AlmostHuman
Earth
Model X, Cybertruck
Human
Couple things to consider I would say. At a higher state of charge of 100% I have seen it drop off faster than sitting at 50% state of charge. Same as Stuck4ger, have seen close to 10% per day on our 2020 X with Sentry enabled at the airport. Starting at 100% with Sentery I’d say you seeing 10% loss is not crazy and likely nothing to be worried about.
jimnycricket65
jimnycricket65
Couple things to consider I would say. At a height state of charge of 100% I have seen it drop off faster than sitting at 50% state of charge. Same as Stuck4ger, have seen close to 10% per day on our 2020 X with Sentry enabled at the airport. Starting at 100% with Sentery I’d say you seeing 10% loss is not crazy and likely nothing to be worried about.
“…nothing to worry about” is What I was trying to derive at. I went on a longer ride so I charged it to 100% and forgot to change the setting back to 80% last night. I don’t have temperature climate setting thing on. As I walk to the I try to cool the car. I am usually parked under the shade at home and at work.
tmeyer3
Trevor
www.meyerwine.com
Computer Scientist, Vintner
Was this happening on version 2024.26.3.1 or 2024.20.7? I haven't experienced -10% overnight with sentry on, that seems excessive. Are you have a ton of sentry events? I'm not sure if that even effects it or not, but just curious.
igs
CT, MX, MY
igs
CT, MX, MY
Someone just make this a sticky so we don't get a thousand threads like this asking the same question that's been answered a million times already.
Babab
Babab
Boston, Ma
Model x, Cyberbeast, BMW i8
Yea sentry drains a good amount on my model x (cybertruck coming Oct-Dec). Turn it off if you need to save juice. Also it turns itself off when my car is below 50 miles of range.
Drain will also happen in colder temps.
mdcoleman
Matt
Seattle, WA
2024 CyberTruck FS (123D) (124XX VIN)
Construction Manager / Contractor
*Cue the argument* thread
Come on
