LOSS OF SYSTEM REDUNDANCY DETECTED - Potential major system failure
JeffDaniel
JeffDaniel
Jeff
West Little Rock, Arkansas
www.RedshiftWLR.com
Jeep
Video Production
If it is coolant, a small bubble will be fine and you may not have another issue, but a large one will get worse and you may eventually need a tow.
I had that issue at 200 miles....and it was fine for a week, but then got bad.
Well dang. That sucks you had to deal with that. I’m going to be selfish and hope that doesn’t happen to me before my service appointment. But your feedback is really helpful. Thank you.
I am assuming you’ve had no further problems after getting the issue corrected?
SCTesla
22 Model S, 24 CT
I had to get a rear oil pump replaced as well, but semi unrelated.
Also my tonneau is not sealed at all. Like the bed fills with water, buy I'm waiting on weather seal to come in. That's not a big deal IMO
Celiboy
Marcel
Clovis, California
UPDATE #2: ERROR UPON ERRORS
Opened up the service screen. The amount of alerts is almost comical.
Damn! That’s crazy. I’m glad the reset worked and you are still able to drive it until they can figure out what’s wrong.
TwiztOG43
Las Vegas
Tesla Model Y Performance, Tesla Model Y LR
I’m @ 8k miles. Had this happen @ around 6k miles. While I was showing off exterior features of the truck for about 20 minutes. I got back in afterwards and had this error. Stepped away from vehicle, locked it and returned. Error was gone and roadside/overide notification disappeared. Been fine since.
Had the same thing happen at 1k miles. Hasn’t returned. Currently at 7300 miles.
elonmu5k
Connecticut
CT, M3P
Just had this happen to me. I bought/picked up the truck, drove it 100 miles home, and got hit with the red screen of death, redundancy failure error, rear steering disabled, can’t put in drive etc as I was pulling into my neighborhood. A tow truck is on the way. Hopefully it’s a quick fix in the service center?
JeffDaniel
JeffDaniel
Jeff
www.RedshiftWLR.com
Jeep
Video Production
Have you tried to power cycle it (walk away, let it shut down, and then walk back to it)?
elonmu5k
Connecticut
CT, M3P
Yeah. They walked me through that over the phone with roadside. No luck with it, and when I came back an hour later it was throwing the same errors.
Reactions: REM
JeffDaniel
JeffDaniel
Jeff
www.RedshiftWLR.com
Jeep
Video Production
Damn, that sucks. I’m sorry to hear that. Fortunately the issue should be a simple permanent fix. Still doesn’t make this moment any easier. Please share once you’re back up and running.
JeffDaniel
JeffDaniel
Jeff
www.RedshiftWLR.com
Jeep
Video Production
**** UPDATE ****
I was told today that this error was caused by a "Steering Column Failure". It had something to do with the sensors failing. The redundancy checks that they have built in (to prevent a steering failure) apparently worked. Parts are now on order. Doesn't seem to be backordered. Will update when I learn more.
They are also replacing the compressor for the suspension. I was getting a "suspension unable to raise" error on occasion.
Reactions: REM
