Sandman1962
- Sel
- Apr 18, 2023
- San Diego
- Model S , Model X
do you just need one set of these, or two?Used some longer bolts and nylon washers. That fixed the clearance issue. However the housing needed modification and it still isn't on right.
Anyone who's not handy or patient with their work, I'd recommend skipping this product for now. Should not have to run to home Depot for parts and break apart plastic to get this to work.
Those that want to try, these are the bolts and washers I got.
Once you get those, there are some thin plastic pieces inside the housing which just twist off worth a pair of pliers real easy.
I feel like if they include these bolts and washers, provide actual instructions for both sets of bolts, and trim the housing, then this would be great.
Side note, it feels solid once in. Doubt it will move around at all unless you're on a Baja run.
