beastew
Stew
Oceanside, NY
Cyberbeast Foundation Series
Here are some pics of the installed Offroad Lightbar. Service center did not tuck the harness under the roof applique. I did not expect them to splice the wires in or remove the blackout film tape, they are not permitted to do so or even assist.
Updated with more info:
They kept the truck overnight to allow the urethane time to dry. The lightbar is "glued" to the glass. The service rep said "she hopes I like the way it makes the truck look. You can't use it on the road." Tesla's installation instructions states "Tesla employess are not permited to connect or assist with the connection..." so you are left on your own. I'm hoping to have time to connect it tomorrow or over the weekend. I'll try to take some pictures of the connection process and what it looks like with the lights on.
The wire does not have to stand up like that and will be tucked neatly away after the harness is hooked up. They asked me a couple of times if I want them to install it since it is not removeable.
I did not hear any wind noise from the lightbar and I always wondered what effect it will have on range. Guess the real way to find out is put it in a wind tunnel.
Wheel covers were not in stock. I put my center ring back & lug nut covers.
Tesla Cybertruck Offroad Light Bar Installed by Service Center! Menu first look: Ditch Lights & Flood Flights functions 20240919_093507
Tesla Cybertruck Offroad Light Bar Installed by Service Center! Menu first look: Ditch Lights & Flood Flights functions 20240919_101838
Tesla Cybertruck Offroad Light Bar Installed by Service Center! Menu first look: Ditch Lights & Flood Flights functions 20240919_101731
Tesla Cybertruck Offroad Light Bar Installed by Service Center! Menu first look: Ditch Lights & Flood Flights functions 20240919_093524
Tesla Cybertruck Offroad Light Bar Installed by Service Center! Menu first look: Ditch Lights & Flood Flights functions 20240919_101921
UPDATE:
Connected & working. Here is how I did it, not a recommendation:
Lifted the roof applique using plastic trim tools. Rolled up a towel to hold it out of the way.
Removed the shrink tubing from the lightbar side and stripped back the insulation from the vehicle side to expose wires.
Soldered the appropriate wires together: red to red with blue stripe, black to black with blue stripe, & green to green.
Slid heat shrink tubing – 3/16” (previously put in place) and shrank it using a heat gun.
Slid a large heat shrink tube – 3/8” over the 3 connections for added abrasion protection and shrank that down (probably over kill)
Routed the cable neatly alongside the clip receptacle, checked the wire from the light to make sure it doesn’t get pinched. Snapped the applique back into place.
Tested the light as I went along (after steps 3,5, & 6)
Tesla Cybertruck Offroad Light Bar Installed by Service Center! Menu first look: Ditch Lights & Flood Flights functions 20240920_100346-jpg
Tesla Cybertruck Offroad Light Bar Installed by Service Center! Menu first look: Ditch Lights & Flood Flights functions 20240920_094426-jpg
Tesla Cybertruck Offroad Light Bar Installed by Service Center! Menu first look: Ditch Lights & Flood Flights functions 20240920_103337-jpg
Tesla Cybertruck Offroad Light Bar Installed by Service Center! Menu first look: Ditch Lights & Flood Flights functions 20240920_110552-jpg
Tesla Cybertruck Offroad Light Bar Installed by Service Center! Menu first look: Ditch Lights & Flood Flights functions 20240920_104249-jpg
Tesla Cybertruck Offroad Light Bar Installed by Service Center! Menu first look: Ditch Lights & Flood Flights functions 20240920_105914-jpg
Operating lightbar was added "Controls > Outlets & Mods "
Tesla Cybertruck Offroad Light Bar Installed by Service Center! Menu first look: Ditch Lights & Flood Flights functions 20240920_153419-jpg
Tesla Cybertruck Offroad Light Bar Installed by Service Center! Menu first look: Ditch Lights & Flood Flights functions 20240920_153518-jpg
jonesw67
Warren
AR
FS Cyberbeast
Nice, How long did it take them and did they provide the process or point you in the right direction for the steps needed to "finish" it ?
beastew
beastew
Stew
Oceanside, NY
Gaximus
Mead, CO
Software Developer
Is there any noticeable wind noise when driving?
Once you hook it up, can you post pictures how bright it is?
EMoeller
Eric
West Marin, California
Porsches (992 Turbo S, 993 Turbo, 993 Targa)
Geologist
I like the look. At least they are finally starting the process of completing orders that were delivered months ago. The light bar and wheel covers are the only check list items I have left to complete.
Then its on to self parking and supervised FSD....
rlhamil
Richard
Glen Burnie, Maryland
There is a link
https://service.tesla.com/docs/Serv...ruck_Off_Road_Lightbar_Harness_Connection.pdf
Unfortunately it doesn't give the document, just an error message.
That link is pointed to from
https://service.tesla.com/en-US/documents?searchText=CD-24-90-001
The service document for installation (minus that last step!) does describe tucking in the wire, at least (near the bottom).
https://service.tesla.com/docs/Cybe...UID-3FB15C20-B219-4700-A53A-D946616091A9.html
jf64k
Thanks for sharing, OP!!
I think it looks great. Can't wait for them to be in-stock in the shop so I can get one on my FS AWD.
Looking forward to the hook-up and light pics!!
beastew
beastew
Stew
Oceanside, NY
I did not hear any wind noise from it and I always wondered what effect it will have on range. Guess the real way to find out is put it in a wind tunnel.
