Powershare Gateway (3V) is only needed for Powershare only setups.
If you have a Backup Switch or other version of Gateway, that is all that is needed.
I do not think that is [necessarily] the case, but I also do not know enough of how these things are implemented (e.g., regionally, energy supplier, configuration) to say. I have non-Tesla solar and a backup generator/transfer switch, and these were all in place when Tesla sent an installer to build my Powershare system. That was almost 2 years ago and it still doesn't work. What I mean by that is that it cannot automatically detect a power outage and shift to the truck for power. My transfer switch is downstream of the Gateway.
Lame 😮💨
Want some peanut gallery tech support?
Lame 😮💨
Thanks for the clear response. You say the Gateway is not necessary and Tesla providers say it is but still doesn’t work. I was just pointing that out.
Gateway 3V is required for Powershare backup
Gateway non-3V or Backup Switch are required for Powerwall backup and eventually PW with Powershare backup
by lame I meant that the installer didn't get yours working. Your setup does need a Gateway 3V and I'd help troubleshoot, if you want.
PungoteagueDave
Boynton Beach
Exactly. This "dirty power" narrative reminds me of the people who used to cover their electric outlets so the electrons didn't spill out.
Question to clarify on the Powerwall update. Does this new software/Powerwall update mean that we'll be able to do at least power to home (and perhaps power to grid where allowed) without the installation of the Tesla Gateway? Will the current Powerwall 3 be sufficient?
Powerwall 3 by itself is not sufficient. Tesla specified my system last summer and it was installed last fall with Gateway 3. By careful - the PowerShare Gateway that is a checkbox with a CT order will NOT work for systems with solar. I ended up dealing directly with Tesla engineering on this and there is no question that the myth out there that Powerwall by itself will allow full integration for grid-connected backup with CT and Powerwall and solar is simply not true. Gateway is required but there are three (or four) Gateways out there and only Gateway 3 will work. How sure am I about this? Tesla voluntarily replaced the Gateway 3V that they sent me upon CT purchase with a standard Gateway 3 because it was their error. They laughed when I asked them about whether there is any truth to the idea that a grid-connected system with all three functions - solar, Powerwall 3 and CT backup could function with only Powerwall and no Gateway. Now the question is whether it ever works. Software is hard. Still holding my breath….
Non-Gateway configurations in a Powerwall system:
Gateway 3 can be replaced with the Tesla backup switch
Non-backup system using the Tesla Remote Energy Meter instead of Gateway 3
PungoteagueDave
Boynton Beach
With solar? Tesla told me no when I suggested backup switch to save cost. Non-backup defeats purpose IMO.
resellpanda88
NY
Cyber Truck
Hey guys. If I don't have powerwall backup but have non tesla solar panels can I get a 3v gateway and have it work as a backup from my truck?
PungoteagueDave
Boynton Beach
Yes, but solar won’t be integrated - it will be separate and depending on how you install, you would need an automatic switch to disconnect the panels from the grid during an outage, which you likely already have - the Gateway performs that function for the truck, and does so for solar panels but my understanding is that is true only if they are attached to Powerwall. Tesla did my installation but used non-Tesla panels, so I doubt that’s a factor.
Coolhandz
Nicholas
Johnstown, CO
ts.la
The solar does not need to be attached to a powerwall for this to function.
Tesla Cybertruck PowerShare with Powerwall UPDATE from Wes! 1781201323949-fr
Trevor
michigan
Cybertruck Founders edition
Ummm, no. But it looks like the FUD has an active audience.
Ask a question, get a snarky uninformed baseless response. Cool cool. Thanks for adding literally nothing. Some of us just want to learn. Good to know this is not a forum for learning or asking questions. Not everyone has some big agenda. Some of us just want to do the things the best way we can with the information available. Being kind is free.
PungoteagueDave
Boynton Beach
Correct, that's what I said. At that point the solar isn't managed or even known about by the Tesla installation (Gateway, CT, switch). When a power loss occurs, the solar has to be set to shut down its grid connection before the Gateway will sense the power loss and kick in the CT battery backup function. I suspect this takes a few seconds more during cutover compared to a Tesla-centric system. Tesla has designed Powerwall to be the center of its home electricity system, managing charging (through Gateway) and grid connection, with a built-in solar inverter. My point to the original connection is that it isn't necessary to have Tesla-branded solar to do any of this - the Powerall and its built-in inverter are agnostic as to the source of solar power input - so even an existing solar panel owner can retrofit Tesla systems with no added or replacement sunk cost.
UL1741 solar up to 11.5kW works seamlessly with Powershare.
The solar in that diagram is on the load side of the Gateway 3V. When the grid goes down, solar automatically shuts off. When Powershare kicks on (Gateway disconnects load side from grid and Cybertruck starts exporting) the solar inverters start producing again.
PungoteagueDave
Boynton Beach
Understood, I believe consistent with my comment - the existing power cutoff, whatever that is, for the existing solar, would need to be eliminated, with the Gateway 3 taking over that job - so it isn't just adding Gateway to make it happen, requires reconfiguration? What's missing in that diagram is the current grid switch that turns off solar when the grid is down. I may have said it in a confused way, pardon my relative lack of expertise on this topic.
