Gaximus
Mead, CO
Software Developer
I have replace my rear view mirror with a rear view mirror screen. It looks completely factory, even used the CT mirror mount to make it work.
Tesla Cybertruck Rear view mirror camera[updated camera/ screen solution - installed notes & photos IMG_2463
Tesla Cybertruck Rear view mirror camera[updated camera/ screen solution - installed notes & photos IMG_2473
Tesla Cybertruck Rear view mirror camera[updated camera/ screen solution - installed notes & photos IMG_2474
Tesla Cybertruck Rear view mirror camera[updated camera/ screen solution - installed notes & photos IMG_2475
The screen supports 2 inputs. One is on top of the truck and wired in through the tiny-gap between the glass and the trim. The other camera is mounted on the rear headliner and points into the vault.(so I can keep an eye on my dog when she is back there)
the current rear view camera I have sucks, and have a much better one on order, the view angle is just two much. It’s about the same as the factory camera, which is good for reversing, but not good for seeing cars behind you when driving.
This setup also uses 12v I found in the ceiling, and powers on when the car powers on.
Here are some better pics of the mirror, it’s not the best, and there is no way to adjust the brightness, so I’m not sure how great that will be at night.
Tesla Cybertruck Rear view mirror camera[updated camera/ screen solution - installed notes & photos IMG_2478
Tesla Cybertruck Rear view mirror camera[updated camera/ screen solution - installed notes & photos IMG_2480
Tesla Cybertruck Rear view mirror camera[updated camera/ screen solution - installed notes & photos IMG_2477
This is the only thing I hate, but doesn’t look horrible.
I went through 3 mirrors before getting to this one. The others had slightly better image, and CarPlay built in. Which was assume, but they just rubberbanded to the existing mirror, which I would have fixed by just 3D printing a new mirror stem and mounting it to the screen. But the power and camera connection came out the top, making it look horrible. I wanted a factory look. Also this mirror supports two camera inputs, the others only supported one
Mirror:
https://www.crutchfield.com/I-rRAFc0001/rf/5ac54708-2806-4413-8283-b697c2e4b7f4/ use this link to sign up, and you get $20 rewards points.
after you create an account, buy the mirror here.
Mirror link
Vault camera:
https://a.co/d/cGqgwzf
Rear view camera:
https://a.co/d/7lFGqNM current one(not recommended, but works)
https://a.co/d/aUNTucG on order will update when I get it installed.
Extension cable for vault camera:
https://a.co/d/6U8Yt5S
Adapter for rear view camera:
https://a.co/d/eyGCxl3
You’ll also need 2.1mm barrel plugs to wire in.
Instructions (very vague, could make video if enough interest)
1. Remove all header trim from the interior of the truck, can leave driver side. (Tesla docs has instruction)
2. Find 12v power supply, I used the radio antenna module, it’s above the driver. I haven’t used radio in 15 years, so I left it unplugged, to avoid pulling too much amperage from that circuit. Note: It’s actually 15ish volts, but all hardware is for commercial applications, so it was rated at 12-24 volt
3. Remove factory mirror, will need to destroy it(unless you’re lucky, but consider it a loss, it was worthless anyway (although it was beautiful in its design)).
4. Open both mirrors and swap out the stem from the factory to the new one. Had to open it and remove the screen and electronics to make this work, take your time, it’s worth it.
5. Remove triangle cover on front window, and the PRDL panel and route the wires up into the main header trim.
6. Worst part: route the wires from the header to the back top of the truck. I went up through the 48 accessory hole, cut the grommet and siliconed the new wires in place, had to remove that whole top sail, and the panel above the door open button. Tesla docs again
7. I double sided the rear view camera to the top see pics, and routed the wires through a tiny hole I cut in the rubber gasket between the glass and the back. Tiny amount of silicon to seal it back up.
8. Mount the vault camera to the rear header trim, double sided sticky tape, I removed all mounting hardware and front glass from the camera(get closer to the window, so the IR lights don’t wash out the video)
9. Tuck it all back together and post pics here.
Update: Got a new camera with better view angle,120 vs 170(updated in another post but wanted to add here).
Also 3D printed a cover, not perfect, but way better than just the camera.
Tesla Cybertruck Rear view mirror camera[updated camera/ screen solution - installed notes & photos IMG_2582
Tesla Cybertruck Rear view mirror camera[updated camera/ screen solution - installed notes & photos IMG_2585
W
CyberZephyr
Long Island, New York
2021 MY, 2023 MX
that looks so great!!!!
Gaximus
Gaximus
Mead, CO
Software Developer
I don't want to insult an otherwise stellar looking install, but...
...Wouldn't the point of a rear view camera to be able to see with the tonneau closed?
There are two cameras, one is one top of the truck and can always see backwards, or I can switch to another IR capable camera that lets me see in the vault. The button on the mirror switches between them.
Gaximus
Gaximus
Mead, CO
Software Developer
the camera mirror I use is 4K and the rear camera is 2.5K awesome quailty. i am making a version 2 of the install process
What mirror did you use? I tried a few that claimed to be 4K, they were much clearer than this one, but looking into the actual specs they were much lower resolution. I went through 5 cameras, 2.5k(didn’t work) 1080p, which outputs a 1080p signal, but the specs say(480 sensor). I’ve all but given up on a good camera, unless I want a monster ugly thing on the roof. I looked into splitting the signal from the factory rear camera, got the cables and every thing, but the view angle is too steep.
Okay, that is super-awesome ^-^
FuryEV
Cybertruck AWD and Cybertruck Beast
JOMISE 4K+2.5K Detached Rear View Mirror Camera,10.88" Mirror Dash Cam Front and Rear Dual Camera for Car, Mirror Backup Camera with Parking Monitoring/Night Vision/G-Sensor/32GB Card Included https://a.co/d/8YOvG5N
I have and install video and review on my YT channel
Gaximus
Gaximus
Mead, CO
Software Developer
I do like the detaching front camera, I had seen your video a while back. One thing I noticed, and I could be wrong, it looks like you go under the side airbags, instead of over them. You may want to reroute if that’s the case. It won’t stop the airbags, but the airbags will rip the screen off, at a very high speed, maybe smashing into someone’s face.
Gaximus
Gaximus
Mead, CO
Software Developer
The WOLFBOX G900Pro 12MP WiFi Touch Screen Rear View Mirror Dash Cam Smart Mirror
is currently available for preorder. Looks like a great option for a rearview digital mirror
Wolfbox G900Pro
I looked into the Wolfbox, I was a more trust worth brand than the other "over-the-mirror" solutions. But it didn't have CarPlay, and I wanted that at the time. Also didn't have 2 camera inputs. Also the forward facing cam is useless on all those, due to the CyberTruck Triangle windshield thing it sits behind.
Fabville
Kevin
Washington State
www.fabville.com
The camera showing the vault would be great to keep an eye on any loads you’re carrying, etc. I’ll likely look at going with the same setup you have later.
